[Mapbender-users] Mapbender - Apache 2 - IE 6
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Fri Apr 16 09:24:03 EDT 2010
Hi Frank,
what version of Mapbender are you running? I assume these are
synchronisation issues with iframes, but I'm not sure. Some issues have
been resolved, especially as Mapbender 2.6+ have the map in a DIV.
Thanks,
Christoph
Jäger schrieb:
> Hallo,
> some days ago we changed Apache 1.3 to Apache 2.2.
> Mapbender-Guis should load faster now ...
> http://www.mapbender.org/Installation_de#Apache_Kompression
> http://www.mapbender.org/Installation_en#Apache_output_compression
> Since this change some Users have Problems:
> - Guis don't load complete.
> - Maps don't load.
> It seems to be a Problem only with IE-Version 6.
> http://www.mapbender.org/Browser
> Is there any known problem with IE6 and Apache's compression?
> Can I solve the Problem on server's site (conf?).
> That may be faster then update hundrets of Users to IE8.
> Frank_______________________________________________
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
