[Mapbender-users] Re: Error installation mapbender 2.6.2
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Mon Aug 9 04:41:10 EDT 2010
Christoph Baudson (Wheregroup) wrote:
> Hello,
> seems like the file name was misspelled in the source code, it should
> have been
> ui.tabs.js
> but is
> .ui.tabs.js
> I will create a ticket and fix it in 2.6.2. Can you try renaming the
> file in your login.php?
> Thanks
> Christoph
On a second thought, I think this bug is unrelated to your problems. You
can removed the call to .ui.tabs.js altogether, as everything seems to
be contained in the jQuery UI built loaded before. See
http://trac.osgeo.org/mapbender/ticket/673
Christoph
> sandramp wrote:
>> Hi Karim,
>> Thanks for your help. Following your advice, I have installed Firefox
>> (is
>> this one ok?? ;-)) and the message shown is (more or less, I
>> translated it):
>> Connection to the server has been restarted while the page was being
>> loaded. Site is temporally not available or too busy. Try again
>> in a few moments. If you cannot load any page, check the network
>> connection of your system If your system or network are
>> protected by a firewall or proxy, check that
>> Firefox has permission for accessing the web.
>> I thought I turned the firewall off to avoid problems, but I've
>> checked it
>> again. Now I also turned off something like "Domain Profile" and I
>> noticed
>> that the "Private Profile" is active, but Firewall is turned off.
>> Maybe the answer is very simple, but how do I verify that I can
>> access the
>> database as the Mapbender user? The database including the table mb_user
>> with the user "root" is there.
>> Here I post you something more from the apache logs. These are the
>> messages
>> from two different log in's
>> (hopefully it is more meaningful to you than it is for me ...):
>> [Sun Aug 08 22:49:53 2010] [notice] Child 2348: Starting thread to
>> listen on
>> port 80.
>> [Sun Aug 08 23:01:16 2010] [error] [client 127.0.0.1] File does not
>> exist:
>> C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/favicon.ico
>> exist:
>> [Sun Aug 08 23:01:19 2010] [error] [client 127.0.0.1] File does not
>> exist:
>> [Sun Aug 08 23:03:18 2010] [error] [client 127.0.0.1] File does not
>> exist:
>> C:/mapbender/http/http
>> [Sun Aug 08 23:03:55 2010] [error] [client 127.0.0.1] File does not
>> exist:
>> C:/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/.ui.tabs.js,
>> referer: http://localhost/mapbender/frames/login.php
>> [Sun Aug 08 23:04:12 2010] [error] [client 127.0.0.1] File does not
>> exist:
>> exist:
>> [Sun Aug 08 23:04:23 2010] [notice] Parent: child process exited with
>> status
>> 255 -- Restarting.
>> [Sun Aug 08 23:04:24 2010] [notice] Apache/2.2.16 (Win32) PHP/5.3.3
>> configured -- resuming normal operations
>> [Sun Aug 08 23:04:24 2010] [notice] Server built: Jul 30 2010 16:15:37
>> [Sun Aug 08 23:04:24 2010] [notice] Parent: Created child process 848
>> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Child process is running
>> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Acquired the start mutex.
>> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Starting 64 worker
>> threads.
>> [Sun Aug 08 23:04:26 2010] [notice] Child 848: Starting thread to
>> listen on
>> port 80.
>> [Sun Aug 08 23:10:55 2010] [error] [client 127.0.0.1] File does not
>> exist:
>> exist:
>> [Sun Aug 08 23:11:06 2010] [notice] Parent: child process exited with
>> status
>> 255 -- Restarting.
>> [Sun Aug 08 23:11:07 2010] [notice] Apache/2.2.16 (Win32) PHP/5.3.3
>> [Sun Aug 08 23:11:07 2010] [notice] Server built: Jul 30 2010 16:15:37
>> [Sun Aug 08 23:11:07 2010] [notice] Parent: Created child process 1672
>> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Child process is running
>> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Acquired the start
>> mutex.
>> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Starting 64 worker
>> threads.
>> [Sun Aug 08 23:11:08 2010] [notice] Child 1672: Starting thread to
>> listen on
>> port 80.
>> Finally, the versions I downloaded are the following:
>> Windows 7 / Apache 2.2.16 / PHP 5.3.3 / Poedit / Postgresql 8.4.4 /
>> Postgis
>> 1.5 / Geoserver 2.0.2 / Mapbender 2.6.2
>> Thanks again!
>> Sandra
FOSS4G 2010
06.-09. September 2010 in Barcelona
http://2010.foss4g.org
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
