[Mapbender-users] Load WMS: Problem with special characters
beyer at multimediaplan.at beyer at multimediaplan.at
Tue Aug 24 12:10:40 EDT 2010
Hello,
sorry for the late answer... I was on holiday last week. :-)
Thanks for the advice. I am going to check whether my database
and the WMS are using UTF-8. My Mapbender version is 2.4.2
(and, unfortunately, I cannot upgrade because I need TreeConfGDE
which does not work in higher versions).
Best regards,
Clemens
> -----Original Message-----
> From: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of
> Astrid Emde
> Sent: Friday, August 13, 2010 2:29 PM
> To: Mapbender User List C
> Subject: Re: [Mapbender-users] Load WMS: Problem with special
> characters
> Hello Clemens,
> There should not be a problem, when you Mapbender uses UTF-8 and your
> Database too. It is also important that the WMS is defined
> with encoding
> UTF-8 (please check this first).
> Maybe you can send an example of these special characters so
> we can have a
> closer look at the problem.
> Which Mapbender version do you use?
> Best regards
> Astrid
> On Wed, August 11, 2010 1:53 pm, beyer at multimediaplan.at wrote:
> > Hi List,
> > I encountered a problem with the Load WMS option a few days
> ago. The WMS
> > was not loaded into my MB, and at least I could figure out that this
> > happened because layer names are written with some special
> characters in
> > the incoming return to the GetCapabilities request. (It's a
> Czech WMS -
> > they have kind a lot of special characters there...)
> > I asked the WMS provider if there were a possibility to put
> a service
> > online without special characters, but unfortunately the
> answer was: "No,
> > we do not have working time left for replacing these characters."
> > I also saved the GetCapabilites doc on my system, replaced
> the special
> > characters manually, and used the URL of the xml file
> instead of the real
> > GetCapabilites URL to load the WMS. It loads into MB then,
> but cannot be
> > displayed in the map (obviously because the layers
> themselvers contain
> > characters, not only the layer descriptions).
> > I would appreciate any help to solve this problem.
> > Regards,
> > Clemens
> > Dipl.-Ing. Clemens Beyer
> > CEIT ALANOVA gemeinnützige GmbH
> > Concorde Business Park 2/F
> > 2320 Schwechat
> > Tel: ++43 664 885 19 555
> > Fax: ++43 1 90360 - 1299
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> FOSS4G 2010
> 6.-9. September 2010 in Barcelona
> http://2010.foss4g.org/
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Siemensstraße 8
>  53121 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 19
>  Fax: +49(0)228 90 90 38 - 11
>  astrid.emde at wheregroup.com
>  www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Astrid Emde
> FOSS4G 2010
>  Astrid Emde
>  Siemensstraße 8
>  53121 Bonn
>  Germany
>  www.wheregroup.com
> Komplementärin:
> vertreten durch:
More information about the Mapbender_users mailing list
