[Mapbender-users] highlight geometry?
Emanuele Zala
emanuele.zala at tg.ch
Tue Dec 7 07:59:17 EST 2010
Hallo Michael,
after digging around a little bit in the code i found a solution which
maybe could also interest other mapbender users (v2.6):
1) get the desired geometry in geojson format (i.e. in postgis SELECT
ST_AsGeoJSON(wkb_geometry)...)
2) create a new GeometryArray and import the geometry (importGeoJSON)
3) create a new Highlight (see javascripts/geometry.js for arguments)
4) Highlight.add(GeometryArray, 'some color')
5) in order to be able to zoom and pan your highlighted geometry,
register it with eventAfterMapRequest
Cheers
Manu
Michael Schulz <mschulz at webgis.de> wrote on 02.12.2010 09:20:
> Hi Manu,
> if you a re using the wfsGazetteer module then a hiliting is already
> implemented. Each resulting geometry is hilited when you move the
> mouse over the corresponding line of the text results (you can
> dis/enable this behaviuor via an element var). If you think of
> hiliting the complete resultset all the time, then this is not
> implemented.
> Cheers, Michael
> 2010/12/2 Emanuele Zala <emanuele.zala at tg.ch>:
>> Dear mapbenders,
>> I've implemented a parcel-search gazetteer and would like to
highlight
>> the geometry of the results. Is there a function similar to
mb_showHighlight
>> that allows to highlight a geometry (area or a polygon)? I'm using
>> v2.6.
>> Reagrds
>> Manu
>> Kanton Thurgau
>> Amt für Geoinformation - ThurGIS-Zentrum
>> Emanuele Zala
>> ThurGIS-Zentrum
>> Verwaltungsgebäude
>> Promenadenstrasse 8
>> 8510 Frauenfeld
>> Tel.: +41 (0) 52 724 16 10
>> Mobile: +41 (0) 76 328 32 08
>> Fax: +41 (0) 52 724 16 00
>> E-Mail: emanuele.zala at tg.ch
>> Homepage: www.geoinformation.tg.ch
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100 Freiburg i. Br.
> Tel: +49 (0)761 705798-102
> Tel: +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Kanton Thurgau
Emanuele Zala
ThurGIS-Zentrum
Verwaltungsgebäude
Promenadenstrasse 8
8510 Frauenfeld
Homepage: www.geoinformation.tg.ch ( http://www.geoinformation.tg.ch/ )
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20101207/c7b8e210/attachment.html
More information about the Mapbender_users
