[Mapbender-users] 2.7
Hernan Olivera
lholivera at gmail.com
Tue Dec 21 17:42:04 EST 2010
Hi again
Is there any guide to use Openlayers apps in 2.7?
thanks
2010/12/21 Hernan Olivera <lholivera at gmail.com>:
> Hi Chris
> You're right. I've done a first install mistaking pg password, and
> reinstalling do not update that (erasing db previolusly). I have to
> delete the folder and reinstall again. Now working.
> Thanks
> 2010/12/21 Christoph Baudson <christoph at baudson.de>:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi Hernan,
>> On 12/21/2010 10:30 PM, Hernan Olivera wrote:
>>> News:
>>> I've installed 2.7 on osgeo4, using different path and different database name.
>>> And pointed another apache virtual directory.
>>> But now I can't login with any user/pass.
>>> 2.6 is still working
>>> What is the procedure to work with 2.7?
>> Please check if the database is installed correctly.
>> You can do this by copying the file
>> tools/mapbender_setup.php
>> to
>> http/php/mapbender_setup.php
>> and calling the script via
>> http://localhost/mapbender/php/mapbender_setup.php
>> (or whatever the path is)
>> Thanks
>> Christoph
>>> thanks
>>>> Hi all
>>>> I'm stucked trying to make it work on centos. Someone have installed
>>>> mb 2.7 on centos successfully?
>>>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
>>>> installation. I hope it must work with all dependences.
>>>> I've seen the demo server with two versions working (2.6.2 y 2.7)
>>>> Do you think it will work if I use the installation script with
>>>> different path and different database name?
>>>> Or it is better to update 2.6.2, or delete it and install 2.7 from scratch?
>>>> I need to be working on 2.7
>>>> thanks
>>>> Hernan Olivera
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.10 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk0RJLEACgkQGtMIfbycMX4PjwCffJX6lArifel2xGFLZag12f4C
>> 2HkAn2GyAr+IbYfXHgDWGYxdJ3bltrzt
>> =q4x/
>> -----END PGP SIGNATURE-----
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users
