[Mapbender-users] 2.7
    Hernan Olivera
    lholivera at gmail.com
    Wed Dec 22 10:03:16 EST 2010
2010/12/22 Hernan Olivera <lholivera at gmail.com>:
> 2010/12/22 Arnulf Christl <arnulf.christl at metaspatial.net>:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hernan Olivera wrote:
>>> Hi again
>>> Is there any guide to use Openlayers apps in 2.7?
>>> thanks
>> Hi Hernan,
>> currently there are only the demo apps. But we are in the final works
>> for 2.7rc release today which will contain a default OL application. We
>> will then start to add some documentation on how to use the application.
> That's ok.
> I have imported the app: psql -f template_openlayers.sql mapbender27
> Ican see it, but the openlayers map an menu are blank.
> suggestions?
Response to myself:
add some wms from mapbender :)
>> Best regards,
>> Arnulf
>>> 2010/12/21 Hernan Olivera <lholivera at gmail.com>:
>>>> Hi Chris
>>>> You're right. I've done a first install mistaking pg password, and
>>>> reinstalling do not update that (erasing db previolusly). I have to
>>>> delete the folder and reinstall again. Now working.
>>>> Thanks
>>>> 2010/12/21 Christoph Baudson <christoph at baudson.de>:
>>> Hi Hernan,
>>> On 12/21/2010 10:30 PM, Hernan Olivera wrote:
>>>>>>> News:
>>>>>>> I've installed 2.7 on osgeo4, using different path and different database name.
>>>>>>> And pointed another apache virtual directory.
>>>>>>> But now I can't login with any user/pass.
>>>>>>> 2.6 is still working
>>>>>>> What is the procedure to work with 2.7?
>>> Please check if the database is installed correctly.
>>> You can do this by copying the file
>>> tools/mapbender_setup.php
>>> to
>>> http/php/mapbender_setup.php
>>> and calling the script via
>>> http://localhost/mapbender/php/mapbender_setup.php
>>> (or whatever the path is)
>>> Thanks
>>> Christoph
>>>>>>> thanks
>>>>>>>> Hi all
>>>>>>>> I'm stucked trying to make it work on centos. Someone have installed
>>>>>>>> mb 2.7 on centos successfully?
>>>>>>>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
>>>>>>>> installation. I hope it must work with all dependences.
>>>>>>>> I've seen the demo server with two versions working (2.6.2 y 2.7)
>>>>>>>> Do you think it will work if I use the installation script with
>>>>>>>> different path and different database name?
>>>>>>>> Or it is better to update 2.6.2, or delete it and install 2.7 from scratch?
>>>>>>>> I need to be working on 2.7
>>>>>>>> thanks
>>>>>>>> Hernan Olivera
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> Hernan Olivera
>> Nothing makes sense, except we make it.
>> http://www.metaspatial.net
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iEYEARECAAYFAk0RvxYACgkQXmFKW+BJ1b3dQACfTr4Uu9ELtSdHMFXhxOOUxeYc
>> 6Y4AoIMFFauiiWWUZPSXUkboW/vnQit1
>> =PxBn
>> -----END PGP SIGNATURE-----
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users
