****SPAM Mail****[Mapbender-users] Fehler beim Hochladen der
Capabilities
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Thu Feb 4 06:33:37 EST 2010
Hallo Marc,
du wolltest ein Capabilities von xxx.de anfordern. Sag doch bitte
Bescheid, wenn Beathe-Uhse (xxx.de) einen WMS vorhält :-)
Gruß
Uli
Marc Jansen schrieb:
> Hallo Martina,
> Sieht so aus als ob
> http://foehr.xxx.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> <http://foehr.xxx.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1>
> kein GetCap ausgibt.
> Kann das sein?
> Ciao,
> Marc
> martina ikert wrote:
>> *Ausgabe bei Angabe von*
>> TEMPLATE
>> "http://foehr.xxx.de:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen
>> <http://foehr.xxx.de:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen>":
>> foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # wget -O /tmp/caps.xml
>> [1] 32326
>> [2] 32327
>> [3] 32328
>> --17:02:13--
>> => `/tmp/caps.xml'
>> Resolving foehr.xxx.de...
>> foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # 127.0.0.2
>> Connecting to foehr.xxx.de|127.0.0.2|:8080... connected.
>> HTTP request sent, awaiting response... 302 Found
>> Location:
>> [following]
>> --17:02:13--
>> => `/tmp/caps.xml'
>> Reusing existing connection to foehr.xxx.de:8080.
>> Location:
>> http://foehr.xxx.de:8080/mapbender1/http/frames/login.php [following]
>> --17:02:13--
>> => `/tmp/caps.xml'
>> HTTP request sent, awaiting response... 200 OK
>> Length: 1,161 (1.1K) [text/html]
>> 100%[========================================================================================>]
>> 1,161 --.--K/s
>> 17:02:13 (70.13 MB/s) - `/tmp/caps.xml' saved [1161/1161]
>> [1] Done wget -O /tmp/caps.xml
>> [2]- Done REQUEST=GetCapabilities
>> [3]+ Done SERVICE=WMS
>> Inhalt von caps.xml:
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
>> <html>
>> <head>
>> Licensing: See the GNU General Public License for more details.
>> http://www.gnu.org/copyleft/gpl.html
>> or:
>> mapbender/licence/
>> <meta http-equiv="cache-control" content="no-cache">
>> <meta http-equiv="pragma" content="no-cache">
>> <meta http-equiv="expires" content="0">
>> <meta http-equiv="Content-Type" content="text/html;
>> "><title>Login</title>
>> <link rel="stylesheet" type="text/css" href="../css/login.css"><script
>> type='text/javascript'><!--
>> function
>> setFocus(){if(document.loginForm){document.loginForm.name.focus();}}//
>> </script></head><body onload='setFocus()'><form name='loginForm' action
>> ='' method='POST'><table><tr><td>Name: </td><td><input type=
>> 'text' name='name' class='login_text'
>> value=''></td></tr><tr><td>Password: </td><td><input type='password'
>> name='password' class='lo
>> gin_text'></td></tr><tr><td></td><td><input type='submit'
>> class='myButton' value='login' title='anmelden'> <a href='../ph
>> p/mod_forgottenPassword.php' title='Passwort vergessen?'
>> target='_blank'>Forgot your password?</a></td></tr></table></form></body>
>> </html>
>> TEMPLATE
>> "/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&gui_id=Expeditionen":
>> foehr:/tmp/MapServ_Test/fgs3/www/cgi-bin # more /tmp/caps.xml
>> Content-type: text/html
>> <HTML>
>> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
>> <!-- MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS
>> =FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORT
>> S=GEOS SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE -->
>> <BODY BGCOLOR="#FFFFFF">
>> msReturnPage(): Web application error. Malformed template name
>> (/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&
>> amp;gui_id=Expeditionen).
>> </BODY></HTML>
>> [1] 32231
>> [2] 32232
>> [3] 32233
>> --16:48:35--
>> => `/tmp/caps.xml'
>> Resolving foehr.xxx.de... 127.0.0.2
>> Length: unspecified [text/html]
>> ] 569 --.--K/s
>> 16:48:35 (33.86 MB/s) - `/tmp/caps.xml' saved [569]
>> <HTML>
>> INPUT=SHAPEFILE -->
>> mapserv(): Web application error. Traditional BROWSE mode requires a
>> TEMPLATE in the WEB section, but none was provided.
>> </BODY></HTML>
>> Deine Erläuterungen zum TEMPLATE habe ich nicht verstanden.
>> Wie muss ich in der map-Datei im TEMPLATE die Anbindung zur Mapbender
>> GUI machen. Ich habe ja keine html-Seite als template.
>> Ich weiß leider nicht mehr, wo ich diese Anweisung im TEMPLATE gelesen
>> habe, aber lokal hat es immer geklappt.
>> Viele Grüße
>> Martina
>> > Date: Mon, 1 Feb 2010 11:46:12 +0100
>> > Subject: Re: ****SPAM Mail****[Mapbender-users] Fehler beim
>> Hochladen der Capabilities
>> > From: mschulz at webgis.de
>> > To: mapbender_users at lists.osgeo.org
>> > Hallo Martina,
>> > könntest Du mal den Inhalt des Ergebnisses des letzten wget Aufrufes
>> > posten? Mit dem Flag wget -O landet ja das Ergebnis in einer Datei (am
>> > besten irgendwo im /tmp), dieses Ergebnis kann der Mapbender noch
>> > nicht korrekt parsen, daher kommt noch der Fehler. Es ist also nicht
>> > nur $1 leer, sondern alle Variablen - aber der erste verletzte
>> > Constraint in der DB löst halt den Fehler aus. Von demher ist die
>> > Fehlermeldung etwas irreführend. Wichtig wäre also weiterhin die
>> > Antwort eures GetCapabilities-Aufrufes per wget zu checken (und evtl.
>> > hier zu posten).
>> > Eine Sache zum Mapserver loggen: Im "normalen" Mapserver-Log (das per
>> > LOG angesprochen wird) erhältst Du zwar letztendlich eine
>> > Fehlermeldung aber kein Debug-output. "Richtiges" debugging am besten
>> > per CONFIG "MS_ERRORFILE" "/tmp/mapserver.log" im MAP-Objekt und DEBUG
>> > on bei den Layern aktivieren.
>> > Zum TEMPLATE: Bist Du Dir sicher, dass Du im TEMPLATE wieder ein
>> > Mapbender-GUI aufrufen willst? Als erstes würde ich mal einfach einen
>> > dummy-template Eintrag nehmen (TEMPLATE "dummy") , das dazu führt,
>> > dass die Ebene abfragbar ist. Dann bei den GUI-WMS-Einstellungen als
>> > info/format "text/plain" auswählen.
>> > Viele Grüße, Michael
>> > Am 1. Februar 2010 10:32 schrieb martina ikert
>> <martinaikert at hotmail.com>:
>> > > Hallo Michael,
>> > > am Freitag abend konnten wir wieder ein bisschen ausprobieren.
>> > > Wir haben die Funktion wget benutzt und bekamen einige
>> Fehlermeldungen, die
>> > > wir nach und nach bereinigen konnten.
>> > > Zuletzt hatten wir folgende Fehlermeldung:
>> > > Ältere behobener Inhalt: von "rlp.log":
>> > > Fri Jan 29 16:51:26 2010,14722,127.0.0.2,Vessels,0,-180.004167
>> > > -164.995833 179.995833 195.004167,-1.000000 -1.000000,,msReturnPage
>> (/tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/frames/index.php?&gui_id=Exp
>> > > editionen). <br>
>> > > Daraufhin haben wir in der map-Datei folgendes ausprobiert, obwohl
>> > > unlogisch, nach untenstehenden Definitionen:
>> > > TEMPLATE
>> "http://ServerURL:8080/mapbender1/http/frames/index.php?&gui_id=Expeditionen"
>> > > #### TEMPLATE
>> > > Aktuellster Inhalt der rlp.log:
>> > > Fri Jan 29 17:12:24 2010,15153,127.0.0.2,Vessels,0,-180.004167
>> > > -164.995833 179.995833 195.004167,-1.000000 -1.000000,,normal
>> execution
>> > > Es gibt also in der log-Datei keine Fehlermeldungen mehr, aber die
>> > > Fehlermeldung beim Hochladen der Capabilities besteht.
>> > > Dazu mal die Eintragung in der pgsql-log:
>> > > 2010-01-29 17:14:55 CET mapbender postgres FEHLER: NULL-Wert in
>> Spalte
>> > > »wms_title« verletzt Not-Null-Constraint
>> > > 2010-01-29 17:14:55 CET mapbender postgres ANWEISUNG: UPDATE wms SET
>> > > wms_title = $1 ,wms_abstract = $2 ,fees = $3, accessconstr
>> > > aints = $4, contactperson = $5,
>> > > ($1 <-- ist anscheind wirklich leer, woher kommt $1 ??
>> > > Was bei unserem WebGIS an sich noch nicht funktioniert ist die
>> > > featureInfo-Funktion.
>> > > Bei einem Klick auf eine Stationskoordinate öffnen sich immer 2
>> > > leere Fenster, nicht aber das HTML-Template. In einer Tabelle
>> sollten die
>> > > Daten zu der Station zu lesen sein.
>> > > Wie kommen wir da weiter?
>> > > Viele Grüße
>> > > Martina
>> > > Auszug aus meinen Recherchen:
>> > > They guide the presentation of results, either a query or a map,
>> to the
>> > > user. Templates are almost always HTML files although they can
>> also be a URL
>> > > (e.g.. http://www.somewhere.com/[ATTRIBUTE]/info.html). URL
>> templates can
>> > > only be used with simple QUERY or ITEMQUERY results so many
>> substitutions
>> > > defined below are not available for them. Simple pan/zoom
>> interfaces use a
>> > > single template file while complicated queries often require many
>> templates.
>> > > Templates often use JavaScript to enhance the basic interface.
>> > > msReturnPage(): Web application error. Malformed template name¶
>> > > This error may occur when you are attempting to use a URL template
>> for a
>> > > query. The issue is that URL templates are only allowed for query
>> modes that
>> > > return only one result (e.g. query or itemquery)
>> > > You can only use a URL template for a query in mode=query or
>> mode=itemquery.
>> > > If you try it with mode=nquery or mode=itemnquery, you will get
>> the error:
>> > > Content-type: text/html msReturnPage(): Web application error.
>> Malformed
>> > > template name
>> > >> Date: Thu, 21 Jan 2010 09:17:58 +0100
>> Hochladen der
>> > >> Capabilities
>> > >> Hallo Martina,
>> > >> klar, das ist die Fehlermeldung im Mapbender-Log. Wenn der Mapbender
>> > >> meldet das die WMS-Version die Not-Null Bedingung verletzt ("Error:
>> > >> FEHLER: NULL-Wert in Spalte »wms_version« verletzt
>> > >> Not-Null-Constraint"), heißt das soviel wie, das in der Antwort auf
>> > >> die GetCapabilities-Anfrage vermutlich gar keine WMS-Getcapabilities
>> > >> drinnen sind. Daher hatte Armin schon vorgeschlagen:
>> > >> "in der class_connector.php function load einfach mal ein $e=new
>> > >> mb_exception('class_connector.php: loaded external data: ',$data);
>> > >> eintragen
>> > >> (vor der return.. zeile)"
>> > >> also ein zusätzlichen Log-Eintrag zu erstellen. Der bisherige Auszug
>> > >> aus dem Logfile zeigt die Standard-Fehlermeldung vom Mapbender, der
>> > >> zusätzliche Eintrag würde Dir den Inhalt der GetCapabilities-Antwort
>> > >> im Log anzeigen. Als quasi äquivalente Möglichkeit kannst Du den
>> > >> GetCapabilities Aufruf auch von dem Mapbender-Server (aber nicht aus
>> > >> der Mapbender-Oberfläche) per wget absetzen um mal zu sehen, was da
>> > >> eigentlich zurückkommt.
>> > >> Am 21. Januar 2010 08:38 schrieb martina ikert
>> > >> > Hallo Michael,
>> > >> > ich habe dir noch einmal die Fehlermeldung kopiert. Das war der
>> Tipp von
>> > >> > Armin.
>> > >> > 2010.01.15, 17:59:48,mb_validateSession.php: GUI: admin2_de,
>> checking
>> > >> > file /mapbender1/http/php/mod_updateWMS.php...session valid.
>> > >> > 2010.01.15, 17:59:48,mb_validatePermission.php: checking file
>> > >> > /mapbender1/http/php/mod_updateWMS.php...permission valid.
>> > >> > 2010.01.15, 17:59:48,connector: unable to load:
>> http://our-server.domaine.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
>> > >> > 2010.01.15, 17:59:48,Error while executing prepared statement in
>> /tmp/MapServ_Test/fgs3/www/htdocs/mapbender1/http/php/mod_updateWMS.php:
>> > >> > Sql: UPDATE wms SET wms_version = $1 ,wms_getcapabilities = $2
>> > >> > ,wms_getmap = $3 ,wms_getfeatureinfo = $4 ,wms_getlegendurl
>> = $5
>> > >> > ,wms_getcapabilities_doc = $6 ,wms_upload_url = $7, wms_owner
>> = $8,
>> > >> > wms_timestamp = $9 WHERE wms_id = $10, Error: FEHLER:
>> NULL-Wert in
>> > >> > Spalte »wms_version« verletzt Not-Null-Constraint
>> > >> > Viele Grüße
>> > >> > Martina
>> > >> >> Date: Wed, 20 Jan 2010 16:25:38 +0100
>> Hochladen
>> > >> >> der
>> > >> >> Capabilities
>> > >> >> Hallo Martina,
>> > >> >> kannst Du dich auf dem Server wo der Mapbender läuft einloggen
>> und
>> > >> >> dort auf der Kommandozeile mal folgenden Befehl absetzen:
>> "http://our-server.domaine.de:8080/cgi-bin/mapserv?map=/tmp/MapServ_Test/fgs3/www/cgi-bin/expeditions.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1"
>> > >> >> Dann sollte in der Datei caps.xml im /tmp Verzeichnis die
>> Antwort auf
>> > >> >> die GetCapabilities-Anfrage stehen, was recht wahrscheinlich
>> > >> >> irgendeine Fehlermeldung sein wird. Das ist ungefähr das
>> gleiche, wie
>> > >> >> es Armin Retterath schon vorgeschlagen hat, aber ich hatte nichts
>> > >> >> gefunden im thread, ob Du das mal probiert hast.
>> > >> >> Am 20. Januar 2010 16:03 schrieb martina ikert
>> > >> >> > Hallo Karim,
>> > >> >> > in php.ini ist
>> > >> >> > allow_url_fopen = On
>> > >> >> > Wir haben heute wieder viel rumprobiert, aber es ist keine
>> Lösung in
>> > >> >> > Sicht.
>> > >> >> > Beim Upload der Capabilities gibt es immer noch die gleiche
>> > >> >> > Fehlermeldung.
>> > >> >> > So langsam ist es wirklich frustrierend.
>> > >> >> > Hat denn sonst niemand lokal gearbeitet und hat dann die
>> Dateien auf
>> > >> >> > einen
>> > >> >> > Server installiert?
>> > >> >> > Viele Grüße
>> > >> >> > Martina
>> > >> >> >> Date: Mon, 18 Jan 2010 11:15:20 +0100
>> > >> >> >> From: karim at malhas.de
>> > >> >> >> Hochladen
>> > >> >> >> der
>> > >> >> >> Capabilities
>> > >> >> >> Hallo Martina,
>> > >> >> >> > Hat jemand noch einen guten Tipp?
>> > >> >> >> Schau mal nach ob in deiner php.ini
>> > >> >> >> gesetzt ist.
>> > >> >> >> Gruß,
>> > >> >> >> Karim
>> > >> >> >> _______________________________________________
>> > >> >> >> Mapbender_users mailing list
>> > >> >> >> Mapbender_users at lists.osgeo.org
>> > >> >> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> > >> >> > Windows Live: Keep your friends up to date with what you do
>> online.
>> > >> >> Aufwind durch Wissen!
>> > >> >> Qualifizierte Open Source Schulungen bei der
>> > >> >> http://www.foss-akademie.de/
>> > >> >> Michael Schulz
>> > >> >> in medias res
>> > >> >> Gesellschaft für Informationstechnologie mbH
>> > >> >> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
>> > >> >> Schwimmbadstraße 2
>> > >> >> D-79100 Freiburg i. Br.
>> > >> >> Tel: +49 (0)761 705798-102
>> > >> >> Tel: +49 (0)761 705798-0
>> > >> >> Fax: +49 (0)761 705798-09
>> > >> >> http://www.webgis.de / http://www.zopecms.de
>> > >> >> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> > >> >> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> > >> > Windows Live Hotmail: Your friends can get your Facebook
>> updates, right
>> > >> > from
>> > >> > Hotmail®.
>> > >> Michael Schulz
>> > >> in medias res
>> > >> Schwimmbadstraße 2
>> > > Hotmail: Trusted email with powerful SPAM protection. Sign up now.
>> > Michael Schulz
>> > in medias res
>> > Schwimmbadstraße 2
>> Hotmail: Powerful Free email with security by Microsoft. Get it now.
>> <https://signup.live.com/signup.aspx?id=60969>
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
