[Mapbender-users] GazetteerWFS nodes problem
Astrid Emde astrid.emde at wheregroup.com
Mon Feb 8 02:50:21 EST 2010
Hello Edison,
On Fri, February 5, 2010 2:47 pm, Edison Fernando Bravo Chancay wrote:
> Hello list
> What is the maximum number of nodes that a gazetteer can do a search?
> I have more than 20,000 nodes in one polygon and no searching
20.000 nodes if far too much, as the resultGeometry is transfered into
the Client into a GeoJSON.
> and how can I change this parameter?
There is no Mapbender parameter which you can change.
But you could change the WFS access on your data:
If you have your data in a PostgreSQL database you can easily change the
query and do a search on the boundingbox of your polygon or on a
simplyfied polygon with less nodes.
CREATE VIEW query_mytable AS
SELECT gid, name, st_envelope(the_geom) as the geom FROM mytable;
SELECT gid, name, st_simplify(the_geom,100) as the geom FROM mytable;
I hope this information will help.
Best regards
Astrid
[1] http://postgis.org/documentation/manual-1.5/ST_Envelope.html
[2] http://postgis.org/documentation/manual-1.5/ST_Simplify.html
> Edison
> Este mensaje ha sido analizado por MailScanner
> en busca de virus y otros contenidos peligrosos, y se considera que está
> limpio.
> INSTITUTO GEOGRAFICO MILITAR
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Siemensstraße 8
  53121 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
