[Mapbender-users] solved : Cannot copy/rename gui's in MB 2.6
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Tue Feb 16 04:04:07 EST 2010
Thanks Victor,
Victor Moral schrieb:
> Sorry if this is not the right way to discuss bugs or code.
I'm thankful for any kind of bug and error report, so you can't really
do anything wrong here.
However, the preferred way is to create a ticket in our tracker at
http://trac.osgeo.org/mapbender/
Maybe read the information on the front page, this should get you
started. Any questions, please let us know.
> There is an error in :
> class_gui.php .
> Version 2.6
> In line 262
> It says : array_push($t, array("s", "i"));
> Must change to : array_push($t, array("s", "s"));
> It was a problem with the quotes around the fkey_gui_id.
> Please include this in the 2.6 code.
I have included your fix in 2.6 and trunk.
Thanks a lot,
Christoph
> Thanks :)
> vm
> -----Mensaje original-----
> De: mapbender_users-bounces at lists.osgeo.org en nombre de Victor Moral
> Enviado el: jue 11/02/2010 18:41
> Para: Mapbender_users at lists.osgeo.org
> Asunto: [Mapbender-users] Cannot copy/rename gui's in MB 2.6
> Hi,
> i've been testing the MB 2.6 with MySQL looking forward to migrate an old 2.4 installation.
> Everything runs smoothly but i've found problems trying to copy or rename a GUI. No error given, but cannot either copy or clone any GUI.
> Any ideas?
> Thanks and regards from Chile.
> vm
> Mapbender_users mailing list
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
