[Mapbender-users] No default user "root"
Astrid Emde
astrid.emde at wheregroup.com
Fri Feb 19 12:31:53 EST 2010
Hello Peter,
Petr DOBEŠ schrieb:
> Hello,
> can somebody help me, please? After instalation of mapbender I dont have a
> default user "root" in the database, so I cant login me.
> I have checked it also with pgAdmin-SQL (select * from mb_user) and there is
> really no user
It look like your database was not set up correctly.
Please use the Mapbender 2.6 from SVN (there are lot of bugs fixed from
original version 2.6):
http://trac.osgeo.org/mapbender/changeset/5530/branches/2.6?old_path=%2F&format=zip
Then use the install.sh (mapbender/resources/db/install.bat) to install
Mapbender. This script will create the database and fill it with tables
and table entries.
Make sure that the installation went right. Check the log-files.
> When I make a new user, I can login, but "There are no guis available for this
> user" So please how can I create new user with available all guis?
> Mapbender Version 2.5.2 (28-07-2009)
> operating system: Win7
Please use PostgreSQL as administrative database. What database version
do you use?
> Thank you very much
> Petr Dobes
Best regards
Astrid
> Petr DOBEŠ
> ČVUT v Praze, Fakulta stavební
> obor Geodézie a kartografie
> HTW Dresden, Fakultät Geoinformation
> ISC Buddy, ISC Media-calendar
> www.rosenka.cz
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
