[Mapbender-users] OpenLayers-Mapbender
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Mon Feb 22 04:12:53 EST 2010
Hi Valenty,
sorry for replying in english only.
The OpenLayers modules are compatible only to the latest Mapbender
trunk, which will become version 2.7 soon. If you want to try the
current trunk, let me know and I will give you instructions.
Christoph
Valenty Gonzalez schrieb:
> Hola a todos, soy nuevo en la lista y tengo 1 mes usando Mapbender
> Es una aplicación excelente y he podido desarrollar un par de casos de
> estudio en este período.
> Ahora estoy tratando de hacer la integración con OpenLayers, pero no
> sé que parametros colocar para que se activen openlayers y
> openlayers_switch.
> Hay algun SQL que me puedan facilitar para usarlo en la base de datos?
> Tengo Mapbender_2.6 sobre ubuntu 9.10 y mapserver 5.x
> Hasta ahora cree un elemento openlayers y otro openlayers_switch; he
> colocado de diferentes formas los módulos mod_openlayers.php,
> initWMS_openlayers, openlayers.js y mod_openlayers_switch y he
> activado y desactivado mapframe1 haciendo combinaciones pero no
> visualizo openlayers.
> Gracias,
> Valenty Gonzalez
> CREATIVA
> Venezuela
> Hi everyone, I'm new to the list and I have like one month using Mapbender
> It is an excellent application and I have a couple of studies cases in
> this period.
> Now I'm trying to do integration with OpenLayers, but I don't know
> what parameters set to activate openlayers_switch and openlayers.
> Are there any SQL sentence that I can use in the database?
> I have Mapbender_2.6, ubuntu 9.10, mapserver 5.x
> I have tried with create two elements: openlayers and
> openlayers_switch other. I have placed in different ways the modules:
> mod_openlayers.php, initWMS_openlayers, openlayers.js and
> mod_openlayers_switch, and I have enabled and disabled mapframe1 but
> don't work for me.
> Thank's,
> Valenty Gonzalez
> CREATIVE
> Venezuela
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
