[Mapbender-users] WFS Search Result Problem [solved]
    Andreas Voit
    a_voit at gmx.at
    Fri Feb 26 08:08:56 EST 2010
hi,
I tried again to change to wfs 1.0.0 and found the update option under
"Wfs konfiguration GUI zuweisen". After changing the request parameter
to version=1.0.0, and update my wfs, the search result zooms to the
correct location/coordinates.
Former I deleted the whole wfs and inserted it again. Perhaps it was
inserted as wfs 1.1.0 although the request version was on wfs 1.0.0 .
thanks for your help, you saved my weekend ;)
andreas voit
Am 26.02.2010 13:35, schrieb Michael Schulz:
> Hi,
> next try: change the type to "MultiPolygonPropertyType".
> Cheers, Michael
> P.S.: I was struggling with the same stuff recently...
> 2010/2/26 Andreas Voit <a_voit at gmx.at>:
>> hi,
>> thanks for your fast answer, i was very astonished ;)
>> to my problem.
>> - i changed the geoserver wfs settings to normal.
>> - i changed to wfs 1.0
>> - in the mapbender db was MultiSurfacePropertyType and I changed it to
>> MULTIPOLYGON
>> but the error still occurs. the epsq should be the same.
>> and I also get in the error logfile "WFS gazetteer: geometry type unknown".
>> thanks
>> Am 26.02.2010 11:12, schrieb Michael Schulz:
>>> Hi,
>>> welcome to Mapbender!
>>> WFS configuration is still a bit complicated, although Mapbender
>>> really does a good job with that. Some things to check:
>>> - have you uploaded your WFS as version 1.0 or 1.1? With Mapbender 2.6
>>> I'd stick to version 1.0
>>> - in Geoserver set your WFS-GML-SRS style to "normal" (under Services
>>> - WFS, scroll down to the bottom)
>>> - check the returned geometryType of your featuretype. I think
>>> Mapbender will only handle the "frequently" used ones, like POLYGON,
>>> MULTIPOLYGON, LINESTRING, etc... I am not sure why (I think it has to
>>> do with what kind of datastore you use), but Geoserver sometimes
>>> exposes your featureType as MultiSurfacePropertyType or the like...
>>> (if that has happened, you may need to change the geometryType by hand
>>> in the mapbender DB)
>>> - make sure you connect the wms layer to the right wfs conf (but i
>>> think if you already get results, that's already done)
>>> - epsg-srs must match between WMS-GUI-setting and WFS featuretype
>>> - your coordinate example seems to me as if you bitten by the
>>> coordinate axis order confusion with wfs 1.1: see the first point.
>>> These are some points to check. Mapbender 2.6 should work well with
>>> Geoserver 2.0.1, at least I have it working with epsg:31467.
>>> Have fun, Michael
>>>> hello,
>>>> I'm new to mapbender. I use mapbender 2.6, postgresql 8.4, geoserver
>>>> 2.01, xampp 1.7.3, windows xp sp3, firefox 3.6 .
>>>> To my problem:
>>>> I use geoserver as my datacenter. I use the wms to show my maps. I
>>>> started to use wfs for searching. Therefor I use the gazetteerwfs
>>>> module. Over the WFS come multipolygons from my postgresql db.
>>>> My Problem occurs when I use the searching. I use a dropdown menu to
>>>> select a value. the selection finds the correct feature and when I click
>>>> at the result it starts zooming. But it ends up with a white map. When I
>>>> mouse over the result, the polygon gets highlighted.
>>>> I found out, that the zoomed feature has incorrect coordinates.
>>>> I mean the correct coordinates are for example 734078.4, 214992.6 and
>>>> the zoomed feature has 214992.6, 734078.4.
>>>> I use EPSG 31259.
>>>> To find a solution I used firebug. I found the function setResult(event,
>>>> index) under http/javascript/mod_wfs_gazetteer_client.php and chanced
>>>> the extend calculation to
>>>> parent.mb_calculateExtent(targetArray[0], bbox[0].y, bbox[0].x,
>>>> bbox[1].y, bbox[1].x); .
>>>> After that the wfs search result zoomed to the correct extend, but the
>>>> highlighting doesn't show up. In my opinon the highlight feature
>>>> coordinates are still uncorrect.
>>>> I also should mention, I looked into the mapbender logfiles and found
>>>> out, that when I press the wfs search button, it writes an error into
>>>> the logfile: [TIMESTAMP] ERROR: WFS gazetteer: geometry type unknown.
>>>> could that be the problem for the incorrect coordinates? I also don't
>>>> understand the unknown geometry type error.
>>>> does anybody know how to fix the coordinate problem?
>>>> thanks
>>>> Andreas Voit
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Andreas Voit
>> http://andreasvoit.heim.at/
>> Windows kam, sah und versagte
Andreas Voit
More information about the Mapbender_users
