[Mapbender-users] Mapbender and GetFeatureInfo
    Sven Böhme
    boehme at supportgis.de
    Wed Jan 20 10:21:15 EST 2010
Marc,
It works. Thank you!
Sven
Am 20.01.2010 14:56, schrieb Marc Jansen:
> Hi Sven,
> I suppose you control the HTML which is sent by the Server in response
> to the GetFeatureInfo-Request?
> If so, a link like:
> <a href="http://www.example.com/" onclick="return
> setOpenerLocation(this.href);">Click here for even more information</a>
> and a JavaScript-function:
> function setOpenerLocation( url ) {
>    if (url && window.opener) {
>        window.opener.location.href = url;
>        return false;
>    return true;
> *could* work. I am not 100% sure whether window.opener is the
> reference you need. It might be that you need to traverse more, e.g.
> window.opener.parent.frames[0]  ...
> or something like that... that depends heavily on the structure and
> hierarchical position of the initial document that opened the popup.
> I could imagine even more problems if the GetFeatureInfo-HTML is
> istself the result of a HTTP-redirect, a technique I have seen in some
> GetFeatureInfo-solutions.
> Regards and good luck,
> Marc
> PS: Of course this is all untested.
> Sven Böhme wrote:
>> Hi List,
>> I integrate Mapbender as iframe in a website. When I open the
>> GetFeatureInfo from one service (html), I like to link to antoher
>> homepage and close the page where Mapbender is intergated? Is this
>> possible?
>> Sven
Dipl.-Geogr. Sven Böhme
CPA Systems GmbH
Grantham-Allee 2-8
D-53757 Sankt Augustin
Tel.: +49 (0) 2241 / 25 94 – 24
Fax.: +49 (0) 2241 / 25 94 - 29
www.cpa-systems.de
Handelsregister:
HRB 9706, Amtsgericht Siegburg
Geschäftsführer:
Dr.-Ing. habil. Christoph Averdung
Dr.-Ing. René Thiele
Dr.-Ing. Matthias Ellsiepen
More information about the Mapbender_users
