AW: AW: [Mapbender-users] WFS Problem
Kesting, Arne Arne.Kesting at velbert.de
Fri Jul 30 03:00:49 EDT 2010
Hallo Astrid,
Danke für den Link. Ich habe jetzt erstmal Mapserver 5.2.1 installiert, damit hat die Addressensuche leider auch nicht funktioniert, immer noch die Meldung im mapbender error-log:
ERROR: class List: function getIndex: member index -1 is not valid
Das Absetzen von DescribeFeatureType-Request im Browser ergab:
http://web-test-neu/cgi-bin/mapserv.exe?map=../../maps/wfs_address.map&Version=1.0.0&SERVICE=WFS&Request=DescribeFeatureType&TYPENAME=address
<schema targetNamespace="http://mapserver.gis.umn.edu/mapserver" elementFormDefault="qualified" version="0.1">
<import namespace="http://www.opengis.net/gml" schemaLocation="http://ogc.dmsolutions.ca/gml/2.1.2/feature.xsd"/>
<element name="address" type="ms:addressType" substitutionGroup="gml:_Feature"/>
<complexType name="addressType">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="msGeometry" type="gml:GeometryPropertyType" minOccurs="0" maxOccurs="1"/>
<element name="oid" type="string"/>
<element name="gid" type="string"/>
<element name="hsnr" type="string"/>
<element name="hsnrz" type="string"/>
<element name="nr" type="string"/>
<element name="name_gross" type="string"/>
<element name="name_maski" type="string"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
Aber ein GetFeature-Request funktionierte nicht:
http://web-test-neu/cgi-bin/mapserv.exe?map=../../maps/wfs_address.map&Version=1.0.0&SERVICE=WFS&Request=getFeature&TYPENAME=address&Filter=<Filter><PropertyIsLike><PropertyName>name_maski</PropertyName><Literal>Am</Literal></PropertyIsLike></Filter>
 <?xml version="1.0" encoding="ISO-8859-1" ?>
- <wfs:FeatureCollection xmlns:ms="http://mapserver.gis.umn.edu/mapserver" xmlns:wfs="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://ogc.dmsolutions.ca/wfs/1.0.0/WFS-basic.xsd http://mapserver.gis.umn.edu/mapserver http://web-test-neu/cgi-bin/mapserv.exe?map=../../maps/wfs_address.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=address&OUTPUTFORMAT=XMLSCHEMA">
- <gml:boundedBy>
  <gml:null>missing</gml:null>
  </gml:boundedBy>
  </wfs:FeatureCollection>
Irgendwie finde ich den Fehler nicht. Wäre für Hilfe dankbar.
Mit freundlichen Grüßen
Arne Kesting
_______________________________
Stadt Velbert
Technische Verwaltungsdienste
Geodaten und Vermessung
Am Lindenkamp 31, Raum 228
42549 Velbert
Tel.: 02051/26-2647
Fax: 02051/26-2784
Email: arne.kesting at velbert.de
Internet: http://www.velbert.de
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde
Gesendet: Freitag, 30. Juli 2010 08:48
An: Mapbender User List
Betreff: Re: AW: [Mapbender-users] WFS Problem
Hallo Arne,
der Upgrade auf den neuen MapServer 5.6.5 sollte auch mit dem MS4W-Paket kein Problem sein.
Eine Beschreibung findest Du unter:
http://www.maptools.org/ms4w/index.phtml?page=RELEASE_mapserver_ms4w3.x_dev-5.6.5.html
Schönen Gruß
Astrid
Kesting, Arne schrieb:
> Hallo,
> Danke an Michael und Karim für die Hilfe. Dann bleibt mir wohl nichts anderen übrig, als den Mapserver neu zu installieren.
> Arne Kesting
> Stadt Velbert
> 42549 Velbert
> Tel.: 02051/26-2647
> Fax: 02051/26-2784
> Michael Schulz
> Gesendet: Donnerstag, 29. Juli 2010 11:16
> Betreff: Re: [Mapbender-users] WFS Problem
> Hey Karim,
> ja, das wird den Nagel auf den Kopf treffen. Das Problem war tatsächlich erst vor einigen Wochen schonmal da. Wenn ich das richtig sehe, dann läuft der Mapserver unter Windows (ms4w?) und es ist nicht so einfach ne ganz aktuellere Version zu installieren. Evtl. hilft dann nur auf 5.4 zurück zu gehen.
> Michael
> Am 29. Juli 2010 11:04 schrieb Karim Malhas <karim at malhas.de>:
>> Laut folgendem Ticket
>> http://trac.osgeo.org/mapserver/ticket/3235
>> verliert Mapserver 5.6.4 die geometrien wenn er per POST angefragt
>> wird (was im Mapbender der Fall ist), könnte das das problem sein?
>> Es gab auf dieser Liste schonmal ne Lösung aber ich hab grade keine
>> Zeit sie rauszusuchen.
>> Gruß,
>> Karim
>> On Thu, Jul 29, 2010 at 10:47:16AM +0200, Michael Schulz
>> <mschulz at webgis.de> wrote
>>> Hallo,
>>> ja, darauf würde ich jetzt auch tippen. Ich würde mal gml_geometries
>>> und gml_the_geom_type weglassen, außerdem geometrie aus der
>>> include_items liste rausnehmen.
>>> Erstmal muss auf ein getFeature-Request tatsächlich auch 'ne
>>> Geometrie zurückkommen, daher am besten nur per Browser und XML
>>> überprüfen, den Mapbender aussen vor lassen.
>>> Grüße, Michael
>>> Am 29. Juli 2010 10:31 schrieb Kesting, Arne <Arne.Kesting at velbert.de>:
>>>> Hallo,
>>>> Ja, das scheint wohl das Problem zu sein.
>>>> Im Firebug-Output ist die Geometrie leer (geometry = "") und im
>>>> mapbender error-log fehlt die Geometrie ebenfalls
>>>> <gml:featureMember>
>>>>      <ms:address fid="address.2666268">
>>>>        <ms:oid>639077</ms:oid>
>>>>        <ms:gid>2666268</ms:gid>
>>>>        <ms:hsnr>31</ms:hsnr>
>>>>        <ms:hsnrz></ms:hsnrz>
>>>>        <ms:nr>16329</ms:nr>
>>>>        <ms:name_gross>AM LINDENKAMP</ms:name_gross>
>>>>        <ms:name_maski>Am Lindenkamp</ms:name_maski>
>>>>      </ms:address>
>>>>    </gml:featureMember>
>>>> Vor oid müsste "geometrie" kommen (Name der Geometriespalte in DB)
>>>> Hier mal ein Auszug aus dem WFS-Dienst:
>>>> WEB
>>>>  IMAGEPATH "e:/ms4w/tmp/ms_tmp/"
>>>>  IMAGEURL "http://web-test-neu/umn/tmp/"
>>>>  METADATA
>>>>  "wfs_title"            "wfs_address"
>>>>  "wfs_onlineresource"   "http://web-test-neu/cgi-bin/mapserv.exe?map=../../maps/wfs_address.map&"
>>>>  "wfs_srs"              "epsg:31466"
>>>>  "ows_schemas_location" "http://ogc.dmsolutions.ca" # Optional  END
>>>> #METADATA END
>>>> # Start of layer definitions
>>>> LAYER
>>>>  NAME "address"
>>>>  CONNECTIONTYPE postgis
>>>>  CONNECTION "user=xxx dbname=xxx host=xxx port=xxx password=xxx"
>>>>  DATA "geometrie from velbert.v_hnrsuchesort USING UNIQUE gid USING SRID=31466"
>>>>  STATUS on
>>>>  TYPE POINT
>>>>  DUMP TRUE
>>>>  METADATA
>>>>  "gml_featureid" "gid"
>>>>  "wfs_title" "AdressSuche"
>>>>  "gml_include_items"
>>>> "geometrie,oid,gid,nr,hsnr,hsnrz,name_gross,name_maski" #Optional
>>>> (serves all attributes for layer)  "gml_geometries" "the_geom"
>>>>  "gml_the_geom_type" "point"
>>>>  END #METADATA
>>>> Vielleicht liegt es ja an der MAP-Datei?
>>>> Arne Kesting
>>>> Stadt Velbert
>>>> 42549 Velbert
>>>> Tel.: 02051/26-2647
>>>> Fax: 02051/26-2784
>>>> Michael Schulz
>>>> Gesendet: Donnerstag, 29. Juli 2010 09:50
>>>> Hallo,
>>>> tja, sieht so aus, als ob zwar Attribute aber keine Geometrie beim Ergebnis mitgeliefert würde. Ich vermute mal das da eine Punkt-Geometrie zurückkommen sollte?
>>>> Ist die Geometrie in der eigentlich gelieferten getFeature Antwort enthalten?
>>>> Grüße, Michael
>>>> Am 29. Juli 2010 09:39 schrieb Kesting, Arne <Arne.Kesting at velbert.de>:
>>>>> Hier ist die JSON-Ausgabe von Firebug
>>>>> features
>>>>>        [Object { type="Feature", more...}]
>>>>> 0
>>>>> crs
>>>>>        null
>>>>> geometry
>>>>> id
>>>>>        "address.2666268"
>>>>> properties
>>>>>        Object { oid="639077", more...}
>>>>> gid
>>>>>        "2666268"
>>>>> hsnr
>>>>>        "31"
>>>>> name_gross
>>>>>        "AM LINDENKAMP"
>>>>> name_maski
>>>>>        "Am Lindenkamp"
>>>>> nr
>>>>>        "16329"
>>>>> oid
>>>>>        "639077"
>>>>> type
>>>>>        "Feature"
>>>>> type
>>>>>        "FeatureCollection"
>>>>> Folgender Fehler ist übrigens aufgetreten, Firebug meldet:
>>>>> this.get(-1).e is undefined in map.php myBBOX
>>>>> Arne Kesting
>>>>> Stadt Velbert
>>>>> 42549 Velbert
>>>>> Tel.: 02051/26-2647
>>>>> Fax: 02051/26-2784
>>>>> Kesting, Arne
>>>>> Gesendet: Donnerstag, 29. Juli 2010 09:31
>>>>> An: 'Mapbender User List'
>>>>> Betreff: AW: [Mapbender-users] WFS Problem
>>>>> Hallo,
>>>>> Muss man JSON für den Firebug freischalten? Ich bekomme unter mod_wfs_gazetteer_server.php die Reiter Parameter, Header, Antwort und Cache. Mache das zum ersten mal, deshalb frage ich.
>>>>> Danke.
>>>>> Arne Kesting
>>>>> Stadt Velbert
>>>>> 42549 Velbert
>>>>> Tel.: 02051/26-2647
>>>>> Fax: 02051/26-2784
>>>>> Kesting, Arne
>>>>> Gesendet: Donnerstag, 29. Juli 2010 09:20
>>>>> Hallo,
>>>>> Ich schau gleich mal nach.
>>>>> Was ich festgestellt habe ist, dass im Dialog "WFS laden" der WFS-Dienst My Geoserver WFS eingestellt war, und auch in der PostgreSQL-DB unter gui_wfs die entsprechende ID (1) stand und nicht die meines WFS-Dienstes.
>>>>> Nach Löschen der entsprechenden Zeilen in der DB habe ich den WFS nochmal komplett neu eingeladen und konfiguriert, GUI zugewiesen und auch die ConfID im gazetteer-Modul geändert.
>>>>> Leider immer noch der gleiche Fehler.
>>>>> Arne Kesting
>>>>> Stadt Velbert
>>>>> 42549 Velbert
>>>>> Tel.: 02051/26-2647
>>>>> Fax: 02051/26-2784
>>>>> Michael Schulz
>>>>> Gesendet: Donnerstag, 29. Juli 2010 09:01
>>>>> Hallo,
>>>>> ok, sorry, ich war wohl auf dem falschen Dampfer. Hatte vor kurzem einen ähnlichen/gleichen Fehler und bei mir hings an der verwurschtelten Zuweisung von wfs_confs.
>>>>> Bin die erste Mail nochmal durch gegangen und nach Suche im Quelltext kommt diese Fehlermeldung aus der geometry.js. Bitte mal im Firebug unter Netzwerk nach der JSON-Rückgabe von mod_wfs_gazetteer_server.php schauen - und evtl. posten. Oder kann man das irgendwo live sehen?
>>>>> Viele Grüße, Michael
>>>>> Am 29. Juli 2010 08:30 schrieb Kesting, Arne <Arne.Kesting at velbert.de>:
>>>>>> Hallo,
>>>>>> vielen Dank für die zahlreichen Tipps.
>>>>>> Ich habe in der WFS Verwaltung unter "WFS Konfiguration GUI zuweisen" nachgeschaut und festgestellt, dass zu meiner GUI nur der Adressen-WFS zugeordnet ist, kein Mapbender User oder sonstige WFS-Confs.
>>>>>> Allerdings gibt es z.B. für gui2 keine WFS-Zuweisung, noch nicht einmal Mapbender User, obwohl die Suche nach Usern in der gui2 funktioniert. Komisch. Die einzige GUI, die WFS-Zuweisungen hat ist gui_digitize (Mapbender User, myLines, myPoints, myPolygons).
>>>>>> Jetzt steh ich irgendwie auf dem Schlauch.
>>>>>> Arne Kesting
>>>>>> Stadt Velbert
>>>>>> 42549 Velbert
>>>>>> Tel.: 02051/26-2647
>>>>>> Fax: 02051/26-2784
>>>>>> Michael Schulz
>>>>>> Gesendet: Mittwoch, 28. Juli 2010 17:34
>>>>>> Hallo,
>>>>>>> Die WFS-Conf ist mit keinen WMS-Diensten verknüpft, ist für eine Adressensuche auch nicht nötig, oder?
>>>>>> Nö, ich glaube nicht, könnte nur Probleme geben wenn noch Ebenen mit conf-IDs verknüpft sind, wie es z.B. beim Mapbender-user gazetteer der Fall ist.
>>>>>>> Die elementvars des gazetteer-Elements, d.h. wfsConfIDString enthält nur die Nummer des "richtigen" WFS, in meinem Fall 5. In der GUI-WFS-Konfiguration ist auch die Spalte geom richtig gesetzt, sonst fällt mir nichts auf.
>>>>>> Hmm, die Spalte "geom" richtig gesetzt, das hört sich für mich nach der WFS-Konfiguration an, es gibt aber noch die GUI-WFS-Konfiguration, bei der du eine WFS-Conf einem GUI zuordnest. Das muss vorhanden sein, wenn aber deine Suche schon erscheint, ist das wohl schon passiert.
>>>>>> Schau aber mal, ob da noch andere wfs_confs zugewiesen sind, indem du in dem Dialog "alle WFS Confs" und dann deine GUI auswählst. Dann sollten unten rechts in der Liste alle zugewiesenen wfs_confs erscheinen.
>>>>>>> Muss ich vielleicht einen ganz neues gazetteer-Element erstellen?
>>>>>> Nö. Sollte so gehen.
>>>>>>> Arne Kesting
>>>>>>> Stadt Velbert
>>>>>>> 42549 Velbert
>>>>>>> Tel.: 02051/26-2647
>>>>>>> Fax: 02051/26-2784
>>>>>>> Michael Schulz
>>>>>>> Gesendet: Mittwoch, 28. Juli 2010 16:29
>>>>>>> Hallo,
>>>>>>> ich glaube da stimmt etwas nicht mit den zugewiesenen Diensten und den verwendeten WFS-Conf-IDs...
>>>>>>> Sind WMS-Dienste mit der WFS-Conf verknüpft? Sind noch alte Verknüpfungen, z.B. zur Mapbender-User Suche noch irgendwo referenziert? Die Punkte in in GUI-WFS-Konfiguration, GUI-WMS Konifiguration und elementvars des gazetteer-Elements checken.
>>>>>>> Viel Erfolg, Michael
>>>>>>> Am 28. Juli 2010 16:03 schrieb Kesting, Arne <Arne.Kesting at velbert.de>:
>>>>>>>> Hallo Mapbender-Nutzer,
>>>>>>>> ich habe ein Problem bei der Einbindung eines WFS zur Adressensuche.
>>>>>>>> Das Laden und Konfigurieren des WFS ist kein Problem, auch das
>>>>>>>> Zuweisen zu einer GUI funktioniert, allerdings werden keine Suchergebnisse angezeigt.
>>>>>>>> Die Suche bricht ab bei de Meldung "Arranging search results..."
>>>>>>>> Das mapbender_error.log File liefert folgenden Fehler:
>>>>>>>> valid
>>>>>>>> Die Adressen befinden sich in einer PostgreSQL-Datenbank und
>>>>>>>> werden laut Error-Log-File auch gefunden. Die Funktion createFromXml:
>>>>>>>> getfeature zeigt die gefundenen Features (Adressen) richtig an.
>>>>>>>> (ich hatte die Datei class_gml_factory.php abgeändert)
>>>>>>>> Als Template für meine GUI habe ich gui2 gewählt und das
>>>>>>>> gui_element gazetteerWFS entsprechend abgeändert, also eine andere WFS-ID eingegeben.
>>>>>>>> Es wäre nett, wenn mir jemand weiterhelfen könnte. Vielen Dank.
>>>>>>>> Arne Kesting
>>>>>>>> System-Info:
>>>>>>>> Mapbender 2.6.1
>>>>>>>> Mapserver 5.6.3
>>>>>>>> Apache 2.2.15
>>>>>>>> PHP 5.3.2
>>>>>>>> PostgreSQL 8.3
>>>>>>>> _______________________________________________
>>>>>>>> Mapbender_users mailing list
>>>>>>>> Mapbender_users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>>>>> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Aufwind durch Wissen!
>>>>>>> Qualifizierte Open Source Schulungen bei der
>>>>>>> http://www.foss-academy.eu/ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
>>>>>>> Michael Schulz
>>>>>>> in medias res
>>>>>>> Gesellschaft für Informationstechnologie mbH
>>>>>>> Schwimmbadstraße 2
>>>>>>> D-79100  Freiburg i. Br.
>>>>>>> Tel:  +49 (0)761 705798-102
>>>>>>> Tel:  +49 (0)761 705798-0
>>>>>>> Fax: +49 (0)761 705798-09
>>>>>>> http://www.webgis.de / http://www.zopecms.de
>>>>>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>>>>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht
>>>>>>> Freiburg _______________________________________________
>>>>>> Michael Schulz
>>>>>> in medias res
>>>>>> Schwimmbadstraße 2
>>>>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>>>>> Michael Schulz
>>>>> in medias res
>>>>> Schwimmbadstraße 2
>>>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck Eingetragen
>>>> Michael Schulz
>>>> in medias res
>>>> Schwimmbadstraße 2
>>> Michael Schulz
>>> in medias res
>>> Schwimmbadstraße 2
> Michael Schulz
> in medias res
> Schwimmbadstraße 2
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck Eingetragen im
More information about the Mapbender_users mailing list
