[Mapbender-users] Changing Path Var
Thomas Baschetti
info at thomas-baschetti.de
Mon Jun 28 02:32:52 EDT 2010
don't know exactly where to do it for Windows 7, in older Versions of
windows
you could set this in "Systemsteuerung" => System => Erweitert
in Windows 7 this could be "Systemsteuerung" => Benutzerkonten
Another possibility is you use commandline, you could set the path var
there:
set path=%PATH%;C:\Program Files (x86)\PostgreSQL\8.4\bin
This is not a permanent change, it only works in the openend shell.
Oh, and you only have to add the foldername, not the complete path to
you exe,
so C:\Program Files (x86)\PostgreSQL\8.4\bin is sufficient.
Ciao
Thomas
On 27.06.2010 11:35, Sylvia Preuß wrote:
> Hello dear users,
> I'm trying to install mapbender for Windows 7. So far I installed
> Apache Web Server, PHP (ms4w), Postgres, Postgis (Windows
> StackBuilder; the databases contain pgsql-language) and Poedit
> successfully. I downloaded and extracted mapbender.zip and followed
> the installation instructions and made the changes concerning
> httpd.conf, mapbender.conf, po-file to mo-file. After entering
> install.bat on the windows-shell a psql-error occurs. Where do I have
> to set the PATH-Variable and am I right to assume that the path is
> C:\Program Files (x86)\PostgreSQL\8.4\bin\psql.exe? I copied the
> message from the shell:
> Your Choices:
> Databasetype: PostgreSQL
> Encoding: UTF-8
> Database Host: localhost
> Database Port: 5432
> Database Name: mapbendereins
> Database Template: template_postgis
> Database User: postgres
> Looks ok, start install?
> (y)es or (n)o? y
> Sorry, psql not found, must be in PATH-Variable, exiting...
> Finished...check the log files to see if an error occured.
> Drücken Sie eine beliebige Taste . . .
> Thanks in advance!
> sylvia
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20100628/481f1be9/attachment.html
More information about the Mapbender_users
