AW: [Mapbender-users] (no subject)
Leukert, Boris
boris.leukert at wald-und-holz.nrw.de
Mon Jun 28 02:47:24 EDT 2010
Hi Sylvia,
try to set the PATH variable before running the install.bat command:
set PATH=C:\Program Files (x86)\PostgreSQL\8.4\bin:%PATH%
Best regards,
Boris
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Sylvia Preuß
Gesendet: Sonntag, 27. Juni 2010 11:36
An: mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] (no subject)
Hello dear users,
I'm trying to install mapbender for Windows 7. So far I installed Apache Web Server, PHP (ms4w), Postgres, Postgis (Windows StackBuilder; the databases contain pgsql-language) and Poedit successfully. I downloaded and extracted mapbender.zip and followed the installation instructions and made the changes concerning httpd.conf, mapbender.conf, po-file to mo-file. After entering install.bat on the windows-shell a psql-error occurs. Where do I have to set the PATH-Variable and am I right to assume that the path is C:\Program Files (x86)\PostgreSQL\8.4\bin\psql.exe? I copied the message from the shell:
Your Choices:
Databasetype: PostgreSQL
Encoding: UTF-8
Database Host: localhost
Database Port: 5432
Database Name: mapbendereins
Database Template: template_postgis
Database User: postgres
Looks ok, start install?
(y)es or (n)o? y
Sorry, psql not found, must be in PATH-Variable, exiting...
Finished...check the log files to see if an error occured.
Drücken Sie eine beliebige Taste . . .
Thanks in advance!
sylvia
<https://img.web.de/p.gif>
WEB.DE DSL ab 19,99 Euro/Monat. Bis zu 150,- Euro Startguthaben und
50,- Euro Geldprämie inklusive! https://freundschaftswerbung.web.de
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20100628/83a309f8/attachment.html
More information about the Mapbender_users
