AW: [Mapbender-users] Digitizing polygons with en- or exclaves
    Michael Schulz
    mschulz at webgis.de
    Tue Jun 29 05:09:07 EDT 2010
Hi Boris,
just out of curiosity: digitizing normal, "simple" polygons is
working? Are you using mapbender with connectiontype "http" or "curl"?
If  you're not using curl, could you give it a quick try and see if it
works?
I just had a problem with digitizing using geoserver 2.0.2 done from
an productive mapbender26 system, which is not up to date. And I'm
wondering if the error I experienced is resolved with your recent svn
version (Geoserver kept complaining that it "Could not determine
geoserver request from http request") ?
Thx, Michael
2010/6/29 Leukert, Boris <boris.leukert at wald-und-holz.nrw.de>:
> Hi Thomas,
> thanks for your response, I have created a new ticket (#650).
> Best regards,
> Boris
> ________________________________
> Von: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Thomas
> Baschetti
> Gesendet: Dienstag, 29. Juni 2010 07:42
> An: Mapbender User List
> Betreff: Re: AW: [Mapbender-users] Digitizing polygons with en- or exclaves
> Boris,
> i can confirm this behaviour, seems to be a bug.
> Could you please file this in trac?
> http://trac.osgeo.org/mapbender/
> Ciao
> Thomas
> On 28.06.2010 16:18, Leukert, Boris wrote:
> Hi Thomas,
> I have tried both methods:
> - first method: The geometry disappears from the map when pressing the
> combine button.
> - second method: The geometry is combined on the map when pressing the
> combine button but I cannot save
>   the geometry in the database. Error Message: "An error occured.". Please
> see attached Mapbender Logfile.
> I'am using Mapbender 2.6.1 (exported form svn on friday), Geoserver
> 2.0.1, PostgreSQL 8.4.4 and PostGIS 1.5.1.
> Best regards,
> Boris
> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
> Hakenstraße 8D
> 49074 Osnabrück
> Tel: 0541 25 91 90 | mobil 01577 189 25 91
> E-Mail: info at thomas-baschetti.de
> www.thomas-baschetti.de
> Ust-IdNr.: DE264355072
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
