[Mapbender-users] msLoadMap(): Unable to access file.
Astrid Emde astrid.emde at wheregroup.com
Sat Mar 6 07:13:51 EST 2010
Hola Melina,
please check your WMS_ONLINERESOURCE in your MapServer map-file.
In your map-file you use \ but you better should use /.
The getCapabilities request would look like this:
http://190.12.71.69/cgi-bin/mapserv.exe?map=C:/ms4w/ServWMS/LimiteDepart.map&request=getCapabilities&Version=1.1.1&Service=WMS
You have to edit your mapfile because Mapbender gets the wrong information
from the Capabilities-Document (--> not right
C:ms4wServWMSLimiteDepart.map).
Best regards Astrid
On Fri, March 5, 2010 12:20 am, Melina Perez wrote:
> Hi,
> I am writing to request your help, I have installed Mapbender 2.5.2, and
> have problems with the load of WMS, as well load the BD, but the viewer
> get an error: "*Failed to Load WMS "Metadato de Limites Departamentales"
> from Server "
> http://190.12.71.69/cgi-bin/mapserv.exe?map=C:ms4wServWMSLimiteDepart.map"
>  Do you want to try to load it in a new window?"
> I want to upload the WMS is comprised of a subdirectory (called
> *peru500k*) before
> the layer (called *LimiteDepartamental*), and that the Mapbender is
> forcing you to read this subdirectory like a layer. For better
> understanding I attached the ouput of the charged layer:
> id: *0* parent: name: *map_generated_by_gvsig* title: *Metadato de
> Limites
> Departamentales* queryable: *0* minScale: *0* maxScale: *0*
> dataurl:
> metadataurl: EPSG:4326-81.3287-18.4953-68.5896-0.01813
> id: *1* parent: *0* name: *peru500k (PostgreSQL)* title: *peru500k
> (PostgreSQL)* queryable: *0* minScale: *0* maxScale: *0*
> dataurl:
> id: *2* parent: *1* name: *LimiteDepartamental* title:
> *public.limitedepart*queryable:
> *1* minScale: *0* maxScale: *0*
> dataurl:
> metadataurl: EPSG:4326-81.3282-18.3509-68.6523-0.0387767
> I hope anyone can help me about it, I will be very grateful.
> Melina Pérez Pelayo
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
