[Mapbender-users] problem with sld editor and geoserver
zorg zorg at probesys.com
Tue Nov 9 08:14:27 EST 2010
Yes that's what i did
Le 09/11/2010 10:45, Michael Schulz a écrit :
> Hi,
> ok, thanks for that. Do you have assigned a wfs configuration to a wms
> layer on which you want to use the SLD-Editor?
> Cheers, Michael
> 2010/11/9 zorg<zorg at probesys.com>:
>> Hi
>> everything is blank
>> I have investigate a little and in fact when sld.main.php is call hte script
>> doesnt work after line 96 (no error appear)
>> I have try putting echo "test"; and it doesn't show after line 96 (hope i'm
>> clear)
>> /* Check for a related WFS featuretype */
>> $wfs_conf_id = $dbutils->getLayerWfsConfId($_SESSION["sld_gui_id"],
>> $layer_id);
>> if ( $wfs_conf_id ) {
>>         $featuretype_id = $dbutils->getWfsConfFeatureTypeId($wfs_conf_id);
>>         $classWfsConf->getelements($featuretype_id);
>>         $wfs_element = $classWfsConf->elements;
>>         $fts =
>> $styledlayerdescriptor->layers[0]->styles[0]->featuretypestyles[0];
>>         $fts->setElementArray("element_id",$wfs_element->element_id);
>>         $fts->setElementArray("element_name",$wfs_element->element_name);
>> } else {
>>         $wfs_element = false;
>> Le 08/11/2010 20:11, Michael Schulz a écrit :
>>> No, there's no other, my question was more whether the whole window
>>> being completly empty/white or e.g. only the maps or whatever.
>>> I'll have a look into that issue...  Cheers, Michael
>>> 2010/11/8 zorg<zorg at probesys.com>:
>>>> I using mapbender  2.6.2,  GeoServer 2.0.2
>>>> Yes i'm talking about the sld editor popup (is there another one???)
>>>> Le 08/11/2010 16:29, Michael Schulz a écrit :
>>>>> Hi,
>>>>> you mean the Sld-Editor popup window is completly empty? This is
>>>>> Mapbender 2.6.2, right? Which Geoserver are you using?
>>>>> Cheers, Michael
>>>>>> Hi
>>>>>> If i try to use sldeditor with geoserver wms I get a blank page with no
>>>>>> error
>>>>>> in the log i have this
>>>>>> 2010.11.08, 15:33:25,Notice: class_locale: setting locale to fr
>>>>>> 2010.11.08, 15:33:25,Notice: locale fr_FR.utf8 ok on linux
>>>>>> 2010.11.08, 15:33:25,Notice: mb_validateSession.php: checking file
>>>>>> /mapbender/sld/sld_main.php
>>>>>> 2010.11.08, 15:33:25,Notice: gui id not set
>>>>>> 2010.11.08, 15:33:25,Notice: gui id set to guiID: admin_en_services
>>>>>> 2010.11.08, 15:33:25,Notice: mb_validateSession.php: GUI:
>>>>>> admin_en_services,
>>>>>> checking file /mapbender/sld/sld_main.php...session valid.
>>>>>> If you have nay idea
>>>>>> _______________________________________________
>>>>>> Mapbender_users mailing list
>>>>>> Mapbender_users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
