[Mapbender-users] problem with sld editor and geoserver
Michael Schulz
mschulz at webgis.de
Wed Nov 10 08:58:11 EST 2010
Hi Karim,
the sld parser, was done the same way the older versions of the wms
parsing were. The first and presumably not too complicated issue to
overcome is namespace support. The next issue is the supported sld
features problem. Since it was originally done for mapserver, it
covers basically mapserver sld functionality and only geoserver sld
where it overlaps. Although we're talking OGC standards (in my
experience) the SLD implementation varies from WMS to WMS in some
points, which can make parsing an sld pretty complicated (e.g. see an
example for that on the discussion page of the SLD integration
http://www.mapbender.org/Talk:Sld_integration)
I currently checking whether the namespace issue is easy to fix and
will come back with an answer later ...
Cheers, Michael
2010/11/10 Karim Malhas <karim at malhas.de>:
> Hello Michael,
>> ok, I could reproduce this behaviour with MB 2.7 also. This is a
>> problem of the SLD parser (it has nothing to do with the wfs_conf
>> assignment to a wms layer). The SLD-Editor has been initially
>> developed and tested for Mapserver. I have done some things to be able
>> to handle also GeoServer, but that was for GS 1.6/1.7 and especially
>> prior to GS supporting the getStyles request.
>> I think from GS 2 onwards the getStyles request is supported but the
>> SLD parser is currently not able to cope with it. This would mean it
>> will need to be overhauled for this requirement. Unfortunately I don't
>> have enough ressources at the moment to do this.
> Do you have a specific example of where the parsing fails ? No time to
> fix here, just curious.
> Regards,
> Karim
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users
