[Mapbender-users] Digitize multiple geometries with
	similar	attributes possible?
    Christoph Baudson
    christoph at baudson.de
    Fri Nov 19 13:30:04 EST 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 11/18/2010 10:46 AM, Michael Schulz wrote:
> Hi,
> I am wondering whether it is currently possible with the digitize
> module to digitize e.g. several points and then assign them all the
> same attributes at once? A use-case may be: your digitizing all the
> telephone booths in a town. But clearly all booths will get the same
> attribute value "telephone booth". Then when you save them, all
> geometries share the same attribute values. Is that possible? Would it
> only work when e.g. multipoint geometrytype is used?
Just brainstorming:
What you can do is (mis)use the auth_varname wfsconf attribute: In
digitizing, this is used to store the user id in the wfs. Instead of
userid, you could add another expression, which is evaluated by php.
Another thing you could do (on trunk) is create a new module which
registers a function with the openDialog event. You could check whether
the wfs conf of the current geometry matches the telephone booth wfsconf
(configured via element var), and then set the attribute of the geometry.
If you need more details, let me know.
Have a ncie weekend
Christoph
> Thanks for some help or thoughts,
> Michael
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkzmwicACgkQGtMIfbycMX6G+wCcCWfHx1v8WcSDi8jeHVVONKbc
gt4An1YzZPB0rFsOhgC7f2m3Fp+onTfw
=+3wh
-----END PGP SIGNATURE-----
More information about the Mapbender_users
