[Mapbender-users] WFS-Search: Select for Boolean/Integer
"Jäger, Frank (KRZ)"
F.Jaeger at KRZ.DE
Wed Aug 3 05:25:39 EDT 2011
> -----Original Message-----
> From: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of
> Verena Diewald
> Sent: Wednesday, August 03, 2011 9:33 AM
> To: mapbender_users at lists.osgeo.org
> Subject: Re: [Mapbender-users] WFS-Search: Select for Boolean/Integer
> Hi Frank,
> Is your gazetteerWFS module integrated in the tab element vars?
Yes.
> And did you assign your wfs conf to the gui in which you want to use it?
Yes.
> Is the search-Tab working in the right way with other wfs confs?
Yes.
I configured this feature als text-input.
The user has to type in "0" or "-1" and the result is filtered then.
But as select-box it does'nt work.
> Best regards,
> Verena
More information about the Mapbender_users
