[Mapbender-users] Problem with SRS EPSG:4189
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Thu Aug 18 06:28:01 EDT 2011
hello,
in the mapbender.conf file there is a constant which can be set to the srs
which should be handled by the mapbender installation. please uncomment it an
fill in your srs. for the srs which are supported by your wms and which have
no bboxes defined in the capabilities doc new bboxes will be calculated by
postgis as arnulf claimed before.
the function maybe new and it will only work in mapbender 2.7.x - as far as i
know.
best regards
armin
line from mapbender.conf:
#define("SRS_ARRAY", "4326,31466,31467,31468,25832");
Am Donnerstag, 18. August 2011 11:56:31 schrieb Seven (aka Arnulf):
> Valenty,
> in the capabilities document the bounding boxes for the corresponding
> SRS are missing. The only one given is for 4326, which is why this is
> the only one Mapbender will accept.
> <SRS>EPSG:2201</SRS>
> <SRS>EPSG:2202</SRS>
> <SRS>EPSG:2203</SRS>
> <SRS>EPSG:32618</SRS>
> <SRS>EPSG:32619</SRS>
> <SRS>EPSG:32620</SRS>
> <SRS>EPSG:4189</SRS>
> <SRS>EPSG:900913</SRS>
> <LatLonBoundingBox minx="-73.38" miny="0.644" maxx="-58.177"
> maxy="12.198"/>
> To this block wou will need to add the fo0llowing:
> <BoundingBox SRS="EPSG:4189" minx="x lower left" miny="y lower left"
> maxx="x upper right" maxy="y upper right"/>
> and replace "x lower left", "y lower left" and so on with the correct
> coordinates of your country.
> Explanation: In order to be able to start the application with your SRS
> you will need to give Mapbender the initial coordinates, otherwise it
> will not know where to draw the maps.
> Later versions of Mapbender have an additional feature that will
> calculate bounding boxes for all SRS given in the capabilities on its
> own. Mapbender uses PostGIS to calculate the bounding boxes, so it needs
> to be activated and working correctly.
> If you cannot convince GeoServer to add the corresponding section as a
> workaround you can store the Capabilities doc as a file and edit it
> manually. Remember that every time you change anything in the
> capabilities you will have to manually add the coordinates again.
> Just a side note: In the current set up you have the "estados" layer
> right on top of all the other ones. I would suggest to turn this around
> and draw the "estados" as the base layer (listed first in the
> capabilities wiht ID=0), then the others will be displayed on top
> automatically.
> Hope this helps.
> Best regards,
> Arnulf
> On 17.08.2011 00:25, Valenty Gonzalez wrote:
> > Arnulf,
> > I'm using MB version 2.6.2 on Debian Squeeze (Linux desarrollo
> > 2.6.26-2-686). Sorry for not include this information before :-S
> > URL to Capabilities:
> > http://200.75.140.108:8080/geoserver/wms?service=WMS&version=1.1.0&reques
> >t=GetCapabilities
> > Regards,
> > Valenty
> > El 16/08/2011 05:21 p.m., Arnulf Christl escribió:
> >> Valenty,
> >> can you send the URL to the Capabilities document, or if it is local
> >> just the XML file. And what MB version are you running?
> >> Best regards,
> >> Arnulf
> >> ----- Reply message -----
> >> Von: "Valenty Gonzalez" <gvalenty at gmail.com>
> >> An: <mapbender_users at lists.osgeo.org>
> >> Betreff: [Mapbender-users] Problem with SRS EPSG:4189
> >> Datum: Di., Aug. 16, 2011 23:15
> >> Hi,
> >> I need to offer a Geoportal with SRS EPSG:4189
> >> The SRS EPSG: 4189 corresponds to the projection REGVEN,for the Republic
> >> of Venezuela.
> >> Problem is, that I build a WMS from Geoserver with that projection
> >> (4189) and when I go to Mapbender by linking the WMS to a GUI always
> >> reads as SRS EPSG: 4326
> >> This situation succes even if i don'tdeclare 4326 in the configuration
> >> of WMS.
> >> So, when i go to the GUI_settings, this option not give me an
> >> opportunity to select EPSG: 4189 and SRS for the portal service. Only
> >> offer 4326 (by default?)
> >> Any ideas?
> >> Thanks in advance,
> >> Valenty Gonzalez
> >> CREATIVA
> >> Venezuela
> >> Asociación gvSIG
> >> _______________________________________________
> >> Mapbender_users mailing list
> >> Mapbender_users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Armin Retterath
LANDESAMT FÜR VERMESSUNG UND GEOBASISINFORMATION RHEINLAND-PFALZ
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261 492-466
Telefax 0261 492-492
www.lvermgeo.rlp.de
More information about the Mapbender_users
