[Mapbender-users] Installation problem "Compiling .po files..."
dstroeer at uni-osnabrueck.de
Tue Dec 6 10:13:23 EST 2011
Hello,
I still have problems with the installation of mapbender.
I dropped my existing mapbender database and created the file
i18n_update_mo.bat by hand. This means that I copied the content of the
i18n_update_mo.sh - file and saved it as a i18n_update_mo.bat - file.
After that I ran that script and tried to create the mapbender database
again with the install.bat - file. But I got the same error message again!
So know I want to know if I misunderstood your solution or if I made
another mistake?
Thanking you in anticipation,
Dennis
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello,
> at the moment we only provide an i18n_update_mo.sh at mapbender/tools.
> The script install.bat copies i18n_update_mo.sh to i18n_update_mo.bat
> and runs the bat.
> Try to create the file i18n_update_mo.bat by hand and run it. This
> should create the Mapbender mo-files.
> Best regards Astrid
> dstroeer at uni-osnabrueck.de schrieb:
>> Hello everybody,
>> I've got a problem with the installation of mapbender. You can find the
>> error message below...
>> I'm using windows 7 and mapbender 2.7.2 and allready tried it with
>> mapbender 2.6.2. PostgreSQL and Poedit are allready installed, too.
>> So first of all a asked a friend, who also uses mapbender 2.6.2 and
>> windows 7. His application is running fine, but when he tried to run the
>> install.bat for windows again, he got the same message! So we are at a
>> loss...
>> Dennis
>> DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
>> This script will create a database for you and will import the Mapbender
>> data to
>> the new database
>> It will possibly also compile the Mapbender.mo files
>> You need:
>> - a running postgresql 8.x database
>> - database user with write access
>> If everything is prepared you can continue.
>> You can give nearly all arguments on commandline:
>> "C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat <HOST> <PORT>
>> <DBNAME>
>> <DBTEMPLATE> <DBUSER>"
>> e.g.
>> C:\ms4w\Apache\htdocs\mapbender\resources\db\install.bat localhost 5432
>> mapbende
>> r template0 postgres
>> Continue?
>> (y)es or (n)o:y
>> Database host (just hit return for default 'localhost'):
>> Database port (just hit return for default '5432'):
>> Database name:mapbender
>> database template to use (just hit return for default 'template0'):
>> Database user:postgres
>> Database Password will be asked many times during install, unless
>> pgpass.conf is
>> used...
>> Your Choices:
>> Databasetype: PostgreSQL
>> Encoding: UTF-8
>> Database Host: localhost
>> Database Port: 5432
>> Database Name: mapbender
>> Database Template: template0
>> Database User: postgres
>> Looks ok, start install?
>> (y)es or (n)o? y
>> creating db
>> creating schema
>> importing data
>> setting sequences
>> performing updates
>> update to 2.5.1rc1
>> update to 2.5.1
>> update to 2.6rc1
>> update to 2.6
>> update to 2.6.1
>> update to 2.6.2
>> update to 2.7rc1
>> update to 2.7rc2 to 2.7.1
>> update to 2.7.2
>> update sequences
>> Das System kann den angegebenen Pfad nicht finden.
>> please check and edit your mapbender.conf.
>> FINDSTR: i18n_update_mo.sh kann nicht geöffnet werden.
>> Finished...check the log files to see if an error occured.
>> Drücken Sie eine beliebige Taste . . .
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> Where2B Konferenz 2011
> 01. Dezember 2011 in Bonn
> http://www.where2b-conference.com
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> astrid.emde at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAk7WIs4ACgkQBtpS1y1RUoQgfgCePSTuaY4exR0zaMLs96MIej23
> 8FoAoKBTH6z5slBLLbdkdwgXy02lbCLx
> =oeij
> -----END PGP SIGNATURE-----
More information about the Mapbender_users
