[Mapbender-users] WMS start blocked in IE8
a.borgardt at landkreis-cuxhaven.de a.borgardt at landkreis-cuxhaven.de
Mon Dec 19 05:02:23 EST 2011
Hi List,
i created a webapplication called cuxalkis with an inside wms. The
application runs in every browser, but in IE8 (32bit and 64bit) start of
the wms is blocked.
Data from apache error.log
[Mon Dec 19 10:09:44 2011] [error] [client 10.50.50.200]
ALERT-SIMULATION - configured GET variable value length limit exceeded -
dropped variable 'url' (attacker '10.50.50.200', file
'/data/mapbender/http/extensions/ext_featureInfoTunnel.php'), referer:
http://cuxalkis/alkis/frames/index.php?PHPSESSID=cb7b312e65f49d6f1f51965
8d60e146e&gui_id=cuxalkis
[Mon Dec 19 10:18:54 2011] [error] [client 10.50.127.1] File does not
exist: /data/mapbender/http/frames/BLOCKED SCRIPT'<html><, referer:
http://10.50.127.2/alkis/frames/index.php?PHPSESSID=46b781c08bcc4c8d7836
6f748b8bd755&gui_id=cuxalkis
Daten aus dem php.log
[19-Dec-2011 09:59:51] PHP Warning:  DOMElement::setAttribute() expects
parameter 2 to be string, array given in
/data/mapbender/http/classes/class_wmcToXml.php on line 330
fopen(/data/mapbender/core/../log/mb_error_2011_12_19.log) [<a
href='function.fopen'>function.fopen</a>]: failed to open stream: Keine
Berechtigung in /data/mapbender/http/classes/class_mb_log.php on line 59
Debugger aus IE8:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.2; Win64;
x64; Trident/4.0; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1;
SV1) ; .NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR
3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C)
Timestamp: Mon, 19 Dec 2011 09:32:36 UTC
Message: Invalid argument.
map.php
Line: 14373
Char: 3
Code: 0
URI:
http://10.50.127.2/alkis/javascripts/map.php?PHPSESSID=46b781c08bcc4c8d7
8366f748b8bd755&guiID=cuxalkis&PHPSESSID=46b781c08bcc4c8d78366f748b8bd75
5&gui_id=cuxalkis
Invalid argument.
map.php?PHPSESSID=2e0bf6ad70b5140fe99f242af4504ffd&guiID=cuxalkis&PHPSES
SID=2e0bf6ad70b5140fe99f242af4504ffd&gui_id=cuxalkis, line14373
character3 :
el.height = Math.abs(bottom - top) + "px";
Are there any experiences with this behavior? Does anyone know the
error?
Best regards
Andreas Borgardt
Dipl.-Geol. Andreas Borgardt
Landkreis Cuxhaven
06 - GIS-Service
Tel.: 04721/66 23 68
E-Mail: a.borgardt at landkreis-cuxhaven.de
More information about the Mapbender_users mailing list
