[Mapbender-users] RE: WMS start blocked in IE8
a.borgardt at landkreis-cuxhaven.de
Mon Dec 19 09:27:48 EST 2011
>> Data from apache error.log
>> [Mon Dec 19 10:09:44 2011] [error] [client 10.50.50.200]
>> ALERT-SIMULATION - configured GET variable value length limit
exceeded -
>> dropped variable 'url' (attacker '10.50.50.200', file
>> '/data/mapbender/http/extensions/ext_featureInfoTunnel.php'),
referer:
http://cuxalkis/alkis/frames/index.php?PHPSESSID=cb7b312e65f49d6f1f51965
>> 8d60e146e&gui_id=cuxalkis
>This means you have Suhosin enabled on the webserver and it's blocking
what it thinks are exessively
>long queryparameters.
>Solution: Configure suhosin
Hi Karim,
thank you for your answer..but suhosin is already configured;
suhosin.simulation = ON
>> [Mon Dec 19 10:18:54 2011] [error] [client 10.50.127.1] File does not
>> exist: /data/mapbender/http/frames/BLOCKED SCRIPT'<html><, referer:
http://10.50.127.2/alkis/frames/index.php?PHPSESSID=46b781c08bcc4c8d7836
>> 6f748b8bd755&gui_id=cuxalkis
>This is likely also suhosin related
>> Daten aus dem php.log
>> [19-Dec-2011 09:59:51] PHP Warning: DOMElement::setAttribute()
expects
>> parameter 2 to be string, array given in
>> /data/mapbender/http/classes/class_wmcToXml.php on line 330
>> fopen(/data/mapbender/core/../log/mb_error_2011_12_19.log) [<a
>> href='function.fopen'>function.fopen</a>]: failed to open stream:
Keine
>> Berechtigung in /data/mapbender/http/classes/class_mb_log.php on line
59
>You need to give the webserver write permissions on mapbender/log
I did it....
>> Debugger aus IE8:
>> Webpage error details
>> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.2; Win64;
>> x64; Trident/4.0; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1;
>> SV1) ; .NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR
>> 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C)
>> Timestamp: Mon, 19 Dec 2011 09:32:36 UTC
>> Message: Invalid argument.
>> map.php
>> Line: 14373
>> Char: 3
>> Code: 0
>> URI:
http://10.50.127.2/alkis/javascripts/map.php?PHPSESSID=46b781c08bcc4c8d7
8366f748b8bd755&guiID=cuxalkis&PHPSESSID=46b781c08bcc4c8d78366f748b8bd75
>> 5&gui_id=cuxalkis
>> Invalid argument.
map.php?PHPSESSID=2e0bf6ad70b5140fe99f242af4504ffd&guiID=cuxalkis&PHPSES
>> SID=2e0bf6ad70b5140fe99f242af4504ffd&gui_id=cuxalkis, line14373
>> character3 :
>> el.height = Math.abs(bottom - top) + "px";
>Can't say for sure here. Could be related to the overview. Can you try
to disable it, and check if the error persists ?
>Regards,
>Karim
It is related to the overview. If I disable the overview, everything
works fine in IE8. In this GUI I use the same WMS in overview and
mapframe...I have to discover
Thanks a lot!!!
Andreas
P.S. I don't get the mails from the mailinglist, in this case I copied
your answer from the archive
More information about the Mapbender_users
