[Mapbender-users] Problem with fresh install of 2.7.1 on debian
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Jun 1 01:53:51 EDT 2011
i installed the 2.7.1 yesterday without any problems under a fresh debian
squeeze ;-)
http://www.mapbender.org/Installation_de
i used the install script under resources/db/install.sh
please check if the database has been filled! maybe you need a special database
user, cause root or someone else has no rights to fill the database. do you
generated a db template first?
regards
armin
Am Dienstag 31 Mai 2011, 17:28:56 schrieb zorg:
> I'm using debian with apache2 php module
> but even in debug mod I have not error in error.log
> really don't know what I doing wrong
> does anyone have install mapbender 2.7 on debian squeeze
> Le 31/05/2011 16:54, Verena Diewald a écrit :
> > Hi,
> > could you please check your php log. Perhaps you can find some detail
> > information about the problem there.
> > Everything alright in this log while loading your guis?
> > Greetings,
> > Verena
> > Am 31.05.2011 16:53, schrieb zorg:
> >> Still have this problem get the same thing on a fresh debian squeeze
> >> install
> >> no error on apache log
> >> but here is what I have when i log gui1
> >> Le 31/05/2011 15:49, Manns, Marc a écrit :
> >>> the error.log seems to be Ok.
> >>> these errors shouldn't make that trouble.
> >>> You previously wrote: "setup seem to be ok"!
> >>> Do you mean the setup.php?
> >>> You could also check your apache.log
> >>> while loading your application.
> >>> Marc
> >>> Hello
> >>> here is my log
> >>> I have different error
> >>> hope it can help
> >>> Le 31/05/2011 13:56, Manns, Marc a écrit :
> >>>> Hi,
> >>>> if you've installed Mapbender with the install script, you could check
> >>>> the logfile under:
> >>>> /mapbender/ressources/db/error.log
> >>>> ...and see if you had some trouble
> >>>> during the database Installation.
> >>>> regards Marc
> >>>> Hi
> >>>> thanks for your help
> >>>> on the page I have only this
> >>>> 2.7.1 ...loading application 'gui1'
> >>>> plus the images
> >>>> but nothing open
> >>>> no error with firebug
> >>>> what can I do
> >>>> Le 31/05/2011 08:56, Verena Diewald a écrit :
> >>>>> Hi,
> >>>>> do you use Mozilla Firefox? Then you could install the add-on Firebug
> >>>>> for debugging. Reload your guis with an activated Firebug console and
> >>>>> let us know if an error appears there.
> >>>>> Best regards,
> >>>>> Verena
> >>>>> Am 30.05.2011 17:27, schrieb zorg:
> >>>>>> Hi
> >>>>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
> >>>>>> not working I have no error in the log gui_digitize is working and
> >>>>>> other thing also
> >>>>>> I have one more strange thing
> >>>>>> admin_wms_metadata is not working also
> >>>>>> setup seem to be ok
> >>>>>> Does anyone have a clue or can help me to see where look
> >>>>>> thank
> >>>>>> _______________________________________________
> >>>>>> Mapbender_users mailing list
> >>>>>> Mapbender_users at lists.osgeo.org
> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
