[Mapbender-users] Problem with fresh install of 2.7.1 on debian
zorg zorg at probesys.com
Wed Jun 1 05:43:12 EDT 2011
Hi
New thing on my new install i have error log
when i load gui1
here is my log
http://dl.probesys.com/bi3c32ya
hope it can help
Le 31/05/2011 17:28, zorg a écrit :
> I'm using debian with apache2 php module
> but even in debug mod I have not error in error.log
> really don't know what I doing wrong
> does anyone have install mapbender 2.7 on debian squeeze
> Le 31/05/2011 16:54, Verena Diewald a écrit :
>> Hi,
>> could you please check your php log. Perhaps you can find some detail
>> information about the problem there.
>> Everything alright in this log while loading your guis?
>> Greetings,
>> Verena
>> Am 31.05.2011 16:53, schrieb zorg:
>>> Still have this problem get the same thing on a fresh debian squeeze
>>> install
>>> no error on apache log
>>> but here is what I have when i log gui1
>>> Le 31/05/2011 15:49, Manns, Marc a écrit :
>>>> the error.log seems to be Ok.
>>>> these errors shouldn't make that trouble.
>>>> You previously wrote: "setup seem to be ok"!
>>>> Do you mean the setup.php?
>>>> You could also check your apache.log
>>>> while loading your application.
>>>> Marc
>>>> Hello
>>>> here is my log
>>>> I have different error
>>>> hope it can help
>>>> Le 31/05/2011 13:56, Manns, Marc a écrit :
>>>>> Hi,
>>>>> if you've installed Mapbender with the install script, you could
>>>>> check
>>>>> the logfile under:
>>>>> /mapbender/ressources/db/error.log
>>>>> ...and see if you had some trouble
>>>>> during the database Installation.
>>>>> regards Marc
>>>>> Hi
>>>>> thanks for your help
>>>>> on the page I have only this
>>>>> 2.7.1 ...loading application 'gui1'
>>>>> plus the images
>>>>> but nothing open
>>>>> no error with firebug
>>>>> what can I do
>>>>> Le 31/05/2011 08:56, Verena Diewald a écrit :
>>>>>> Hi,
>>>>>> do you use Mozilla Firefox? Then you could install the add-on
>>>>>> Firebug
>>>>>> for debugging. Reload your guis with an activated Firebug console
>>>>>> and
>>>>>> let us know if an error appears there.
>>>>>> Best regards,
>>>>>> Verena
>>>>>> Am 30.05.2011 17:27, schrieb zorg:
>>>>>>> Hi
>>>>>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
>>>>>>> not working I have no error in the log gui_digitize is working and
>>>>>>> other thing also
>>>>>>> I have one more strange thing
>>>>>>> admin_wms_metadata is not working also
>>>>>>> setup seem to be ok
>>>>>>> Does anyone have a clue or can help me to see where look
>>>>>>> thank
>>>>>>> _______________________________________________
>>>>>>> Mapbender_users mailing list
>>>>>>> Mapbender_users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110601/ff7d8c84/attachment.html
More information about the Mapbender_users mailing list
