[Mapbender-users] Problem with fresh install of 2.7.1 on debian
zorg
zorg at probesys.com
Wed Jun 1 05:58:00 EDT 2011
Maybe A bit more info
here is what i have to in mapbender log
2011.06.01, 11:53:38,ERROR: connector: unable to load:
http://localhost/mapbender/javascripts/map.php/../../php/mod_getServiceDisclaimer.php?resource=wms&id=893&languageCode=de&asTable=true
2011.06.01, 11:53:39,ERROR: connector: unable to load:
http://localhost/mapbender/javascripts/map.php/../../php/mod_getServiceDisclaimer.php?resource=wms&id=407&languageCode=de&asTable=true
Le 01/06/2011 07:53, Armin Retterath a écrit :
> i installed the 2.7.1 yesterday without any problems under a fresh debian
> squeeze ;-)
> http://www.mapbender.org/Installation_de
> i used the install script under resources/db/install.sh
> please check if the database has been filled! maybe you need a special database
> user, cause root or someone else has no rights to fill the database. do you
> generated a db template first?
> regards
> armin
> Am Dienstag 31 Mai 2011, 17:28:56 schrieb zorg:
>> I'm using debian with apache2 php module
>> but even in debug mod I have not error in error.log
>> really don't know what I doing wrong
>> does anyone have install mapbender 2.7 on debian squeeze
>> Le 31/05/2011 16:54, Verena Diewald a écrit :
>>> Hi,
>>> could you please check your php log. Perhaps you can find some detail
>>> information about the problem there.
>>> Everything alright in this log while loading your guis?
>>> Greetings,
>>> Verena
>>> Am 31.05.2011 16:53, schrieb zorg:
>>>> Still have this problem get the same thing on a fresh debian squeeze
>>>> install
>>>> no error on apache log
>>>> but here is what I have when i log gui1
>>>> Le 31/05/2011 15:49, Manns, Marc a écrit :
>>>>> the error.log seems to be Ok.
>>>>> these errors shouldn't make that trouble.
>>>>> You previously wrote: "setup seem to be ok"!
>>>>> Do you mean the setup.php?
>>>>> You could also check your apache.log
>>>>> while loading your application.
>>>>> Marc
>>>>> Hello
>>>>> here is my log
>>>>> I have different error
>>>>> hope it can help
>>>>> Le 31/05/2011 13:56, Manns, Marc a écrit :
>>>>>> Hi,
>>>>>> if you've installed Mapbender with the install script, you could check
>>>>>> the logfile under:
>>>>>> /mapbender/ressources/db/error.log
>>>>>> ...and see if you had some trouble
>>>>>> during the database Installation.
>>>>>> regards Marc
>>>>>> Hi
>>>>>> thanks for your help
>>>>>> on the page I have only this
>>>>>> 2.7.1 ...loading application 'gui1'
>>>>>> plus the images
>>>>>> but nothing open
>>>>>> no error with firebug
>>>>>> what can I do
>>>>>> Le 31/05/2011 08:56, Verena Diewald a écrit :
>>>>>>> Hi,
>>>>>>> do you use Mozilla Firefox? Then you could install the add-on Firebug
>>>>>>> for debugging. Reload your guis with an activated Firebug console and
>>>>>>> let us know if an error appears there.
>>>>>>> Best regards,
>>>>>>> Verena
>>>>>>> Am 30.05.2011 17:27, schrieb zorg:
>>>>>>>> Hi
>>>>>>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
>>>>>>>> not working I have no error in the log gui_digitize is working and
>>>>>>>> other thing also
>>>>>>>> I have one more strange thing
>>>>>>>> admin_wms_metadata is not working also
>>>>>>>> setup seem to be ok
>>>>>>>> Does anyone have a clue or can help me to see where look
>>>>>>>> thank
>>>>>>>> _______________________________________________
>>>>>>>> Mapbender_users mailing list
>>>>>>>> Mapbender_users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
