[Mapbender-users] geoserver print request wrong
Armin Retterath armin.retterath at lvermgeo.rlp.de
Thu Jun 16 09:19:23 EDT 2011
dear albert,
you have got a double encoding of the : . i think, that you work with an
apache mod_rewrite. maybe this is the mapbender owsproxy itself, which is used
to secure the access to ows.  please change the options of your rewrite rule
to  [P,L,QSA,NE] - it is really important to use the NE - otherwise the
requests will be double encoded and the geoserver don't know what %253A is ;-)
regards
armin
Am Donnerstag 16 Juni 2011, 14:58:35 schrieb Albert Polze:
> Setup: mapbender: 2.7.1 ; geoserver: 2.1.0 ; Debian 6.0
> Error:
> 2011.06.16, 13:21:51,ERROR: weldMaps2PNG: unable to load image:
> http://xxx.xxx.xx.xx:xxxx/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=G
> etMap&SERVICE=WMS&LAYERS=Casa%253Atest_name,Casa%253AVerkehr_poly_name,Casa
> %253Aexport_roi_1_name&STYLES=,,,&SRS=EPSG:4326&BBOX=-7.67,33.4547,-7.54,33
> .6367&WIDTH=445&HEIGHT=624&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TR
> UE&EXCEPTIONS=application/vnd.ogc.se_xml
> Dear List,
> trying to print my own wms (using printPDF) results in an print without the
> layers. The frame, comments, scalebar etc. are all there. Printing the
> Demis World Map works fine.
> Looking at the request there are some "mistakes" in the URL every colon
> (":") is expressed with "%253A". Changing this in the URL and open it with
> a browser leads to the image that I wanted.
> (Geoserver uses these colons to separate layer stores from layers, but you
> know this...)
> Looking at this old
> http://osgeo-org.1803224.n2.nabble.com/Laden-und-Drucken-externer-Kartendie
> nste-td2057427.html thread  I came to the conclusion that I can solve the
> problem by changing the "class_stripRequest.php".
> Im not into php... so I have no idea what to do, I tried to append this to
> the file...
> function encodeLegGET(){
> 		$this->url = preg_replace("%253A", ":", $this->url);
> 		return $this->url;
> ... but it didnt work.
> I hope somebody can give me a hint.
> best regards A.Polze
> Hallo Liste,
> beim versuch meinen eigenen wms zu drucken, bekam ich ein leeres *.pdf. Der
> Rahmen, Kommentare, Maßstabsleiste etc. waren vorhanden. Den wms der Demis
> World Map konnte ich problemlos drucken.
> Das Problem liegt wohl in den Aufruf, da in der URL alle Doppelpunkte durch
> "%253A" ersetzt wurden.
> (Die Doppelpunkte kommen vom geoserver der damit die Layerstores von den
> Layern trennt aber das ist bekannt).
> Ein älterer
> nste-td2057427.html thread  hat mich auf die Idee gebracht die
> "class_stripRequest.php" anzupassen.
> Dummerweise hört es bei php bei mir auf. Weil es gut aussah habe ich
> folgendes an die Datei noch ergänzt
> ...function encodeLegGET(){
> 		return $this->url;
> ... wie zu erwarten war das aber blödsinn.
> Ich hoffe ihr könnt mir weiterhelfen. Vllt. gibt es ja noch andere
> Lösungen.
> Grüße A.Polze
> http://osgeo-org.1803224.n2.nabble.com/geoserver-print-request-wrong-tp648
> 2919p6482919.html Sent from the mapbender-users mailing list archive at
> Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
