[Mapbender-users] PrintPDF doesn't work
Emilio de Torres Fernández edetorresfernandez at gmail.com
Sun Jun 19 18:38:40 EDT 2011
When I enable the log I get an error loading mapbender after restarting
Apache. I set the following parameters in the php.ini:
   - display_errors = Off
   - log_errors = On
   - error_log = php_errors.log
On the other hand I changed memory_limit from 128M to 256M and I still don't
get the pdf.
Any idea?
Emilio.
2011/6/19 Christoph Baudson <christoph at baudson.de>
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 06/19/2011 09:08 PM, Emilio de Torres Fernández wrote:
> > Hello,
> > I'm trying to print a pdf but I don't get anything. I have checked
> > mapbender.conf and I have correctly configured TMPDIR for temporary files
> > and I have given write permissions for the directory to the
> webserver(Apache
> > running in Windows) but no file is created there.
> > What can be wrong?
> Have you checked your php log file? It is specified under error_log in
> php.ini. Make sure log_errors is activated. Maybe you need to increase
> the memory limit in php.ini in order to print.
> Christoph
> > Best regards.
> > Emilio.
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iQEcBAEBAgAGBQJN/kwLAAoJEDZfGi47DjZ7ZLYH/R3sdALoVDmYJ4sFWxZZ6ebL
> WWJA/yMDMmf7cdPuXMQJz0vkg63SvCJo+fqkoORNHcG+PbQGX+8Q23h+53Zb1fUS
> qghBrhB+srxTJbXIByYb+Tgz9EYGgcIm16pDr1diDCtaD5cyH7ka1PvcvVVUK81f
> /rT6tBEn1Pq4dRo6jAHruRKTYNsd6CKWzlUT2uUHeTbmSqRwuZ7gRZ0bc4Dg8sZ7
> u5cBg5438a9taWBO6B0N1FW2ib6T68pmoO+3xBTla1M44L+9WPm6WsqdtTWSBGij
> wKvzgMFjCbuE+QkEmczzh2w53AI0QywMmUFwmgp5w4dgtkMrmpYBYq4xRg834zk=
> =47s5
> -----END PGP SIGNATURE-----
Un saludo.
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110620/ae7d58ba/attachment.html
More information about the Mapbender_users mailing list
