[Mapbender-users] Update WMS from geoserver misbehaviour
Albert Polze A.Polze at mailbox.tu-berlin.de
Thu Jun 23 09:01:49 EDT 2011
Setup: mapbender: 2.7.1 ; geoserver: 2.1.0 ; Debian 6.0
Hello List
I would like to report a problem while updating a wms. After updating some
layers are missing in WMS application setting and GUIs.
In my environment I use 3 GUIs, each with one WMS from geoserver (stored in
a wms container). The WMS contains 7 Layers (1 raster, 6 vector loaded in
geoserver from disk). Everything worked like it should.
Now I added one of these vector layer into pstgres/postgis database and
loaded it into geoserver (with the same name but different store). After
some time (..serveral hours).. working with the data successfully (including
serveral updates of the wms with no error) the WMS application setting shows
me:
GUI1: everything is good
GUI2 / 3 / wms container: only 3 of 8 layer are shown
When I open the GUIs:
GUI2 / 3: only these 3 of 8 layer are shown
In GUI3 I build in a search (gazetterWFS) for the layer from the database
the odd thing is although the layer is not represented in the WMS
application settings and the GUI I can successfully use the search on this
layer.
No errors in mb_error.log, php_error.log, geoserver-error-log. After
deleting the WMS completely and loading it up again it works fine. Updating
the WMS again doesn't work.
I also got this behaviour with mapbender_2.6.2, geoserver-2.0.2, ubuntu
10.04 as a localhostsystem.
I would provide further information (if needed).
Hallo Liste,
mir ist zum wiederholten male ein Problem untergekommen zu dem ich keine
Erklärung fand. Nach einem update meines WMS finden sich in meinen WMS
Anwedungseinstellungen und GUIs nicht alle Layer wieder.
Ich benutze 3 GUIs mit dem selben WMS vom geoserver. Der WMS wurde in meinen
wms-container hochgeladen und von dort in die GUIs verteilt, er beinhaltet
(1 Rasterlayer und 6 Vektorlayer die vom Verzeichnis aus in geoserver
geladen wurden). Alles funktionierte so wie es sollte.
Als nächstes habe ich einen der Vektorlayer unter einem anderen Datastore
via postgres/postgis Datenbank in den geoserver geladen. Auch hier keine
Probleme. Nach ein paar Stunden und mehrmaligen aktualisieren des WMS (alles
ohne Probleme) passierte folgendes:
WMS Anwendungseinstellungen:
GUI1: alles in Ordnung, so wie es sein sollte
GUI2 / 3 / wms container: nur 3 von 8 Layer werden angezeigt
geöffnete GUIs:
GUI2 / 3: nur die 3 Layer werden angezeigt
In der GUI3 habe ich eine Abfrage (gazetterWFS) für den Layer aus der
Datenbank eingebaut. Merkwürdigerweise kann ich an dem Layer erfolgreich
Abfragen ausführen obwohl er für diese GUI weder in der WMS
Anwendungseinstellung noch in der GUI selber zu sehen ist.
Keine Fehler im mb_error.log, php_error.log, geoserver-error-log. Nachdem
ich den WMS vollsändig gelöscht, neu geladen und zugewiesen habe
funktioniert auch wieder alles. Erneutes updaten des WMS bringt nichts.
Ich hatte dieses Problem auch schonmal unter mapbender_2.6.2,
geoserver-2.0.2, ubuntu 10.04 (als localhostsystem)
Wenn noch informationen fehlen würde ich sie hier reinstellen. (Obwohl ich
hoffe das das Problem nicht wieder auftritt.
Grüße
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Update-WMS-from-geoserver-misbehaviour-tp6508227p6508227.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
