AW: AW: [Mapbender-users] Problem with fresh install of 2.7.1 on debian
Manns, Marc Marc.Manns at remscheid.de
Tue May 31 09:49:17 EDT 2011
the error.log seems to be Ok.
these errors shouldn't make that trouble.
You previously wrote: "setup seem to be ok"!
Do you mean the setup.php?
You could also check your apache.log
while loading your application.
Marc
Hello
here is my log
I have different error
hope it can help
Le 31/05/2011 13:56, Manns, Marc a écrit :
> Hi,
> if you've installed Mapbender with the install script, you could check
> the logfile under:
> /mapbender/ressources/db/error.log
> ...and see if you had some trouble
> during the database Installation.
> regards Marc
> Hi
> thanks for your help
> on the page I have only this
> 2.7.1 ...loading application 'gui1'
> plus the images
> but nothing open
> no error with firebug
> what can I do
> Le 31/05/2011 08:56, Verena Diewald a écrit :
>> Hi,
>> do you use Mozilla Firefox? Then you could install the add-on Firebug
>> for debugging. Reload your guis with an activated Firebug console and
>> let us know if an error appears there.
>> Best regards,
>> Verena
>> Am 30.05.2011 17:27, schrieb zorg:
>>> Hi
>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
>>> not working I have no error in the log gui_digitize is working and
>>> other thing also
>>> I have one more strange thing
>>> admin_wms_metadata is not working also
>>> setup seem to be ok
>>> Does anyone have a clue or can help me to see where look
>>> thank
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
