[Mapbender-users] Problem with fresh install of 2.7.1 on debian
Verena Diewald
verena.diewald at wheregroup.com
Tue May 31 10:54:26 EDT 2011
could you please check your php log. Perhaps you can find some detail
information about the problem there.
Everything alright in this log while loading your guis?
Greetings,
Verena
Am 31.05.2011 16:53, schrieb zorg:
> Still have this problem get the same thing on a fresh debian squeeze
> install
> no error on apache log
> but here is what I have when i log gui1
> Le 31/05/2011 15:49, Manns, Marc a écrit :
>> the error.log seems to be Ok.
>> these errors shouldn't make that trouble.
>> You previously wrote: "setup seem to be ok"!
>> Do you mean the setup.php?
>> You could also check your apache.log
>> while loading your application.
>> Marc
>> Hello
>> here is my log
>> I have different error
>> hope it can help
>> Le 31/05/2011 13:56, Manns, Marc a écrit :
>>> Hi,
>>> if you've installed Mapbender with the install script, you could check
>>> the logfile under:
>>> /mapbender/ressources/db/error.log
>>> ...and see if you had some trouble
>>> during the database Installation.
>>> regards Marc
>>> Hi
>>> thanks for your help
>>> on the page I have only this
>>> 2.7.1 ...loading application 'gui1'
>>> plus the images
>>> but nothing open
>>> no error with firebug
>>> what can I do
>>> Le 31/05/2011 08:56, Verena Diewald a écrit :
>>>> Hi,
>>>> do you use Mozilla Firefox? Then you could install the add-on Firebug
>>>> for debugging. Reload your guis with an activated Firebug console and
>>>> let us know if an error appears there.
>>>> Best regards,
>>>> Verena
>>>> Am 30.05.2011 17:27, schrieb zorg:
>>>>> Hi
>>>>> I've a fresh install of the 2.7.1 mapbender but the gui,gui1,gui2
>>>>> not working I have no error in the log gui_digitize is working and
>>>>> other thing also
>>>>> I have one more strange thing
>>>>> admin_wms_metadata is not working also
>>>>> setup seem to be ok
>>>>> Does anyone have a clue or can help me to see where look
>>>>> thank
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110531/583c9452/attachment.html
More information about the Mapbender_users
