AW: [Mapbender-users] two "tabs"-elements (mod_tab.php) in one GUI
Manns, Marc
Marc.Manns at remscheid.de
Wed Apr 18 02:59:05 EDT 2012
Hi Albert,
Got the same error message (sometimes) in my application.
There is a new config paramater in your mapbender.conf .
Try to set
# security: path to modules
define("CHECK", false);
For security reasons you should
re-activate this parameter after your administration-work has done.
regards Marc
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Albert Polze
Gesendet: Dienstag, 17. April 2012 23:56
An: Mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] two "tabs"-elements (mod_tab.php) in one GUI
Setup: mapbender_2.6.1
Dear List,
I'm trying to put two "tabs"-elements in one GUI. One "tabs"-element contains the treeGDE the second contains Legend, print, etc.
I'm doing this be cause I need every vertical space of the monitor.
Therefore I need the function "expandable" from "tabs"-element-vars.
I have a lot of layers from my WMS and without this function I can only use static-hight for the treeGDE-div, which is not good be cause of different monitors and resultions and without a static-hight the div from treeGDE expands the whole GUI until the mapframe is out of sight be cause of scrolling.
I think this is only possible by using two mod_tab.php files one for the "tabs"-element for treeGDE and another for the rest. If both "tabs"-elements" are pointed to the same mod_tab.php the gui is not working correctly.
Unfortunately I cannot point the second "tabs"-element to another mod_tab.php be cause mapbender denies permission after saving an edited Javascript path (in ..."Anwendungselemente bearbeiten"...).
"/Security alert: You do not have the permission to use the specified module-path./"
This confuses me as well.
I hope somebody can give me a hint.
Albert
Hallo Liste,
ich komm vor grübeln nicht zum schlafen. Ich möchte in meiner GUI zwei "tab"-Elemente einbauen. Ein tab-element hat nur den Inhalt des treeGDE. Das andere die Legende, Druckfunktion und weitere.
Da ich sehr viele Layer in meinem WMS habe, benötige ich den vollen vertikalen Platz vom Monitor. Hauptsächlich benötige ich die Funktion "expandable" vom "tabs"-element-vars da ich die Höhe des treeGDE nicht statisch festlegen will (verschiedene Monitorgrößen, Auflösungen) und auch nicht möchte, dass das div des treeGDE bei großer Layeranzahl den Bereich der GUI so erweitert, dass man durchs scrollen nicht mehr den mapframe sieht.
Ich vermute das läßt sich nur umsetzen wenn das "tabs"-element für den treeGDE und das "tabs"-element für den Rest auf zwei unterschiedliche "mod_tab.php" zugreifen. Denn greifen beide auf die selbe Datei zu zerschießt es mir meine GUI.
Leider kann ich nicht auf eine kopierte "mod_tab.php" zugreifen da mir mapbender beim ändern das Javascript-Pfades in den Anwendungseintellungen den Zugriff verweigert:"/Security alert: You do not have the permission to use the specified module-path./" Was ich nicht ganz verstehe.
Kann mir jemand mit Denkanstößen helfen?
Albert
View this message in context: http://osgeo-org.1560.n6.nabble.com/two-tabs-elements-mod-tab-php-in-one-GUI-tp4891910p4891910.html
Sent from the mapbender-users mailing list archive at Nabble.com.
Mapbender_users mailing list
http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
