[Mapbender-users] How to change a .tif mapbase when the zoom changes
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Jul 17 00:44:30 PDT 2013
hello charles,
mapbender is a ows client. therefor it has not a basemap concept as
openlayers has. if you wan't a possibility to switch between different
backgrund layers this module will help you:
http://www.mapbender.org/SetBackground
see the example:
http://wesseling.wheregroup.com/mapbender/frames/index.php?&gui_id=wesseling_internet
in the right upper corner there is the selectbox.
the thing with the visibility is normally defined by the scale hints of
the wms - in your example geoserver.
in the capabilities document the visibility for the client is defined as
"scale hint". mapbender interprets this scale hints and you can reduce
them in admin1 EDIT GUI-WMS module. if your geoserver has a minscale of
1:10.000 and a maxscale of 1:100.000 you can alter them e.g. to 1:20.000
- 1:80.000.
if you have further questions - don't hesitate to ask
armin
On 17.07.2013 03:06, karchy wrote:
> hello, I need help.
> First of all, i want to know how can i set a basemap in mapbender. I'm using
> geoserver and postgis 2.0 (with raster support). Also i have the .tif files.
> I want to know too, how to change the basemap when I make a zoom in the
> aplication.
> Thaks you very much again.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-change-a-tif-mapbase-when-the-zoom-changes-tp5066905.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
