[Mapbender-users] Display coordinates and info
Jäger, Frank (KRZ)
F.Jaeger at KRZ.DE
Tue Nov 26 03:51:01 PST 2013
Hallo,
> I want to get the coordinates ...
While moving the mouse in the Mapframe you always see the actual coordinates changing under the mapframe.
On mouse-click there is a second row (fixed) with the coordinates of the click-position. You can Copy&Paste this fixed coordinates.
> .. and other information
This is not a function of the Client but oft the Web Map Service (WMS).
A Feature-Info of the WMS gives you Informations to the Objekt you clicked. This can also include some Coordinates.
Which WMS-Server do you use? (UMN-)Mapserver, GeoServer, ..?
You must enable the feature-Info for the WMS in Mapbender for the WMS.
Frank
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-
> bounces at lists.osgeo.org] Im Auftrag von gsetIT
> Gesendet: Dienstag, 26. November 2013 12:36
> An: Mapbender_users at lists.osgeo.org
> Betreff: Re: [Mapbender-users] Display MapBender map in webpage
> Thanks, but that doesn't really help me. I want to get the coordinates (and
> other information) from a point on the map when I click on it and put them in
> some text fields that I have. Can you help?
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20131126/c417479a/attachment.bin>
More information about the Mapbender_users
