[Mapbender-users] Cannot start Mapbender3
Jakob Tworek
jakob.tworek at googlemail.com
Thu Nov 28 06:33:45 PST 2013
Hello list,
I've installed Mapbender3 on Windows 7 (64) System with PHP 5.4.7 and an
Apache2.4. The command-line installation went fine (I followed
http://doc.mapbender3.org/en/book/installation.html) but when I enter
http://localhost/mapbender3/ I just get the following:
<?php
require_once __DIR__.'/../app/bootstrap.php.cache';
require_once __DIR__.'/../app/AppKernel.php';
//require_once __DIR__.'/../app/AppCache.php';
use Symfony\Component\HttpFoundation\Request;
$kernel = new AppKernel('prod', false);
$kernel->loadClassCache();
//$kernel = new AppCache($kernel);
$request = Request::createFromGlobals();
$response = $kernel->handle($request);
$response->send();
$kernel->terminate($request, $response);
I don't get it! Is it a problem with my php configuration or maybe my
apache configuration?
When I enter http://localhost/mapbender3/config.php I just get:
<?php
if (!isset($_SERVER['HTTP_HOST'])) {
exit('This script cannot be run from the CLI. Run it from a browser.');
if (!in_array(@$_SERVER['REMOTE_ADDR'], array(
'127.0.0.1',
'::1',
header('HTTP/1.0 403 Forbidden');
exit('This script is only accessible from localhost.');
require_once dirname(__FILE__).'/../app/SymfonyRequirements.php';
$symfonyRequirements = new SymfonyRequirements();
$majorProblems = $symfonyRequirements->getFailedRequirements();
$minorProblems = $symfonyRequirements->getFailedRecommendations();
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8" />
<link rel="stylesheet"
href="bundles/sensiodistribution/webconfigurator/css/install.css"
media="all" />
<title>Symfony Configuration</title>
</head>
<body>
<div id="symfony-wrapper">
<div id="symfony-content">
<div class="symfony-blocks-install">
<div class="symfony-block-logo">
<img
src="bundles/sensiodistribution/webconfigurator/images/logo-big.gif"
alt="Symfony logo" />
</div>
<div class="symfony-block-content">
<h1>Welcome!</h1>
<p>Welcome to your new Symfony project.</p>
<p>
This script will guide you through the
basic configuration of your project.
You can also do the same by editing the
‘<strong>app/config/parameters.yml</strong>’ file directly.
</p>
<?php if (count($majorProblems)): ?>
<h2 class="ko">Major problems</h2>
<p>Major problems have been detected and
<strong>must</strong> be fixed before continuing:</p>
<ol>
<?php foreach ($majorProblems as $problem): ?>
<li><?php echo
$problem->getHelpHtml() ?></li>
<?php endforeach; ?>
</ol>
<?php endif; ?>
<?php if (count($minorProblems)): ?>
<h2>Recommendations</h2>
<p>
?>Additionally, to<?php else: ?>To<?php endif; ?> enhance your Symfony
experience,
it’s recommended that you fix the following:
</p>
<ol>
<?php foreach ($minorProblems as $problem): ?>
<li><?php echo
</ol>
<?php endif; ?>
<?php if
($symfonyRequirements->hasPhpIniConfigIssue()): ?>
<p id="phpini">*
<?php if
($symfonyRequirements->getPhpIniConfigPath()): ?>
Changes to the
<strong>php.ini</strong> file must be done in "<strong><?php echo
$symfonyRequirements->getPhpIniConfigPath() ?></strong>".
<?php else: ?>
To change settings, create a
"<strong>php.ini</strong>".
<?php endif; ?>
</p>
<?php endif; ?>
<?php if (!count($majorProblems) &&
!count($minorProblems)): ?>
<p class="ok">Your configuration looks
good to run Symfony.</p>
<?php endif; ?>
<ul class="symfony-install-continue">
<?php if (!count($majorProblems)): ?>
<li><a
href="app_dev.php/_configurator/">Configure your Symfony Application
online</a></li>
<li><a href="app_dev.php/">Bypass
configuration and go to the Welcome page</a></li>
<?php endif; ?>
<?php if (count($majorProblems) ||
<li><a href="config.php">Re-check
configuration</a></li>
<?php endif; ?>
</ul>
</div>
</div>
</div>
<div class="version">Symfony Standard Edition</div>
</div>
</body>
</html>
I'm thankful for any help.
Best regards
Jakob
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20131128/2517ec6f/attachment.html>
More information about the Mapbender_users
