[Mapbender-users] Cannot start Mapbender3
    Jakob Tworek
    jakob.tworek at googlemail.com
    Fri Nov 29 03:26:56 PST 2013
Hello Christian,
thanks for the hint and the rapid answer. If I figure it out I will let you
know.
Cheers
Jakob
2013/11/28 Christian Wygoda <christian.wygoda at wheregroup.com>
> Hello Jakob,
> this is definately a problem with your Apache configuration. It doesn't
> know how to handle files ending in .php so it just returns them as plain
> text.
> Not knowing where you got your Apache and PHP and the configuration they
> use it will be hard to give a solution. But I suppose there will be a
> lot of websites describing how to set up Apache with PHP for Windows.
> Maybe too many - specifically a lot of them will be for Apache 2.2 which
> has different configuration options than 2.4 here and there...
> Cheers,
>   Christian
> On Thu, 2013-11-28 at 15:33 +0100, Jakob Tworek wrote:
> > Hello list,
> > I've installed Mapbender3 on  Windows 7 (64) System with PHP 5.4.7 and
> > an Apache2.4. The command-line installation went fine (I followed
> > http://doc.mapbender3.org/en/book/installation.html) but when I enter
> > http://localhost/mapbender3/ I just get the following:
> > <?php
> > require_once __DIR__.'/../app/bootstrap.php.cache';
> > require_once __DIR__.'/../app/AppKernel.php';
> > //require_once __DIR__.'/../app/AppCache.php';
> > use Symfony\Component\HttpFoundation\Request;
> > $kernel = new AppKernel('prod', false);
> > $kernel->loadClassCache();
> > //$kernel = new AppCache($kernel);
> > $request = Request::createFromGlobals();
> > $response = $kernel->handle($request);
> > $response->send();
> > $kernel->terminate($request, $response);
> > I don't get it! Is it a problem with my php configuration or maybe my
> apache configuration?
> > When I enter  http://localhost/mapbender3/config.php I just get:
> > <?php
> > if (!isset($_SERVER['HTTP_HOST'])) {
> >     exit('This script cannot be run from the CLI. Run it from a
> browser.');
> > if (!in_array(@$_SERVER['REMOTE_ADDR'], array(
> >     '127.0.0.1',
> >     '::1',
> >     header('HTTP/1.0 403 Forbidden');
> >     exit('This script is only accessible from localhost.');
> > require_once dirname(__FILE__).'/../app/SymfonyRequirements.php';
> > $symfonyRequirements = new SymfonyRequirements();
> > $majorProblems = $symfonyRequirements->getFailedRequirements();
> > $minorProblems = $symfonyRequirements->getFailedRecommendations();
> > <!DOCTYPE html>
> > <html lang="en">
> >     <head>
> >         <meta charset="UTF-8" />
> >         <link rel="stylesheet"
> href="bundles/sensiodistribution/webconfigurator/css/install.css"
> media="all" />
> >         <title>Symfony Configuration</title>
> >     </head>
> >     <body>
> >         <div id="symfony-wrapper">
> >             <div id="symfony-content">
> >                 <div class="symfony-blocks-install">
> >                     <div class="symfony-block-logo">
> >                         <img
> src="bundles/sensiodistribution/webconfigurator/images/logo-big.gif"
> alt="Symfony logo" />
> >                     </div>
> >                     <div class="symfony-block-content">
> >                         <h1>Welcome!</h1>
> >                         <p>Welcome to your new Symfony project.</p>
> >                         <p>
> >                             This script will guide you through the basic
> configuration of your project.
> >                             You can also do the same by editing the
> ‘<strong>app/config/parameters.yml</strong>’ file directly.
> >                         </p>
> >                         <?php if (count($majorProblems)): ?>
> >                             <h2 class="ko">Major problems</h2>
> >                             <p>Major problems have been detected and
> <strong>must</strong> be fixed before continuing:</p>
> >                             <ol>
> >                                 <?php foreach ($majorProblems as
> $problem): ?>
> >                                     <li><?php echo
> $problem->getHelpHtml() ?></li>
> >                                 <?php endforeach; ?>
> >                             </ol>
> >                         <?php endif; ?>
> >                         <?php if (count($minorProblems)): ?>
> >                             <h2>Recommendations</h2>
> >                             <p>
> ?>Additionally, to<?php else: ?>To<?php endif; ?> enhance your Symfony
> experience,
> >                                 it’s recommended that you fix the
> following:
> >                             </p>
> >                             <ol>
> >                                 <?php foreach ($minorProblems as
> $problem): ?>
> >                                     <li><?php echo
> >                             </ol>
> >                         <?php endif; ?>
> >                         <?php if
> ($symfonyRequirements->hasPhpIniConfigIssue()): ?>
> >                             <p id="phpini">*
> >                                 <?php if
> ($symfonyRequirements->getPhpIniConfigPath()): ?>
> >                                     Changes to the
> <strong>php.ini</strong> file must be done in "<strong><?php echo
> $symfonyRequirements->getPhpIniConfigPath() ?></strong>".
> >                                 <?php else: ?>
> >                                     To change settings, create a
> "<strong>php.ini</strong>".
> >                                 <?php endif; ?>
> >                             </p>
> >                         <?php endif; ?>
> >                         <?php if (!count($majorProblems) &&
> !count($minorProblems)): ?>
> >                             <p class="ok">Your configuration looks good
> to run Symfony.</p>
> >                         <?php endif; ?>
> >                         <ul class="symfony-install-continue">
> >                             <?php if (!count($majorProblems)): ?>
> >                                 <li><a
> href="app_dev.php/_configurator/">Configure your Symfony Application
> online</a></li>
> >                                 <li><a href="app_dev.php/">Bypass
> configuration and go to the Welcome page</a></li>
> >                             <?php endif; ?>
> >                             <?php if (count($majorProblems) ||
> >                                 <li><a href="config.php">Re-check
> configuration</a></li>
> >                             <?php endif; ?>
> >                         </ul>
> >                     </div>
> >                 </div>
> >             </div>
> >             <div class="version">Symfony Standard Edition</div>
> >         </div>
> >     </body>
> > </html>
> > I'm thankful for any help.
> > Best regards
> > Jakob
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Where2B Konferenz 2013
> 12. Dezember 2013 in Bonn
> www.where2b-conference.com
> WhereGroup GmbH & Co. KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Christian Wygoda
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> info at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20131129/f358c917/attachment.html>
More information about the Mapbender_users
