[Mapbender-users] Search Router
Christian Wygoda
christian.wygoda at wheregroup.com
Thu Aug 14 07:20:51 PDT 2014
Hi Stephan,
well, the quotes may work with Doctrine, but it breaks the templating
system. So basically these are not supported right now. Please file a
issue with the Mapbender issue tracker at
https://github.com/mapbender/mapbender/issues.
Sorry for the disappointing answer,
Christian
On 08/14/2014 03:15 PM, Stephan Klemm wrote:
> Hello Astrid, thanks for your solution but it doesn't work with the
> follow exception:
> "An exception has been thrown during the rendering of a template
> ("The name ""Variante"" contains illegal characters. Names should
> start with a letter, digit or underscore and only contain letters,
> digits, numbers, underscores ("_"), hyphens ("-") and colons
> (":").") in MapbenderCoreBundle:Element:search_router.html.twig at
> line 5."
> "CRITICAL - Twig_Error_Runtime: An exception has been thrown during
> the rendering of a template ("The name ""Variante"" contains
> illegal characters. Names should start with a letter, digit or
> underscore and only contain letters, digits, numbers, underscores
> ("_"), hyphens ("-") and colons (":").") in
> "MapbenderCoreBundle:Element:search_router.html.twig" at line 5.
> (uncaught exception) at
> /home/geop/mapbender3/app/cache/dev/classes.php line 9747" The
> Problem exists mainly by parameter "form": class:
> Mapbender\CoreBundle\Component\SQLSearchEngine class_options:
> connection: search_db relation: relation.relation attributes: -
> '"Variante"' geometry_attribute: geom *form: '"Variante"':* type:
> text options: When you have another idea let me know :) Best
> Regards Stephan *Gesendet:* Donnerstag, 14. August 2014 um 14:17
> Uhr *Von:* "Astrid Emde" <astrid.emde at wheregroup.com> *An:*
> "Mapbender User List" <mapbender_users at lists.osgeo.org> *Betreff:*
> Re: [Mapbender-users] Search Router Hello Stephan,
> you should prefer lower case for your table and column names ;)
> You can try to escape your columnames and tablenames if they use
> uppercase.
> Doctrine will understand the " as part of the name. Give it a try
> and please give feeadback how it works
> attributes: - '"Bezeichnung'" - '"Variante'"
> Best regards Astrid
> If this does not work you could use a view with lower case
> instead.
> Best regards
> Astrid
> Am 2014-08-12 16:06, schrieb Stephan Klemm:
>> Sorry, i mean the search router widget...
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
> [1]
>> Best regards
>> GESENDET: Dienstag, 12. August 2014 um 14:19 Uhr VON:
>> Stephan.Klemm at gmx.org AN: mapbender_users at lists.osgeo.org
>> BETREFF: Fw: Simple search Mapbender3
>> Hello,
>> is it possible to use capital letters for attribute-names in the
>> simplesearch and are there examples? My previous attempts failed
>> with capital letters.
>> For example: class:
>> Bezeichnung - Variante - ...
>> Thanks und regards Stephan
>> GESENDET: Dienstag, 12. August 2014 um 11:09 Uhr VON: "Astrid
>> Emde" <astrid.emde at wheregroup.com> AN: "Mapbender User List"
>> <mapbender_users at lists.osgeo.org> BETREFF: Re: [Mapbender-users]
>> Simple search Mapbender3 Hello,
>> at the moment we use simplesearch only with SOLR.
>> Have a look at
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/simplesearch.html
> [2]
>> Best regards
>> Astrid Emde GIS-Consultant
>> Am 2014-08-11 16:15, schrieb mato:
>>> Hello,
>>> is there any example how to set up the simple search widget
>>> for searching using WFS service (geoserver, QGIS)? I am using
>>> mapbender3. Thank you.
>>> -- View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Simple-search-Mapbender3-tp5155816.html
> [3]
>>> Sent from the mapbender-users mailing list archive at
>>> Nabble.com. _______________________________________________
>>> Mapbender_users mailing list Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users [4]
>> Mit freundlichen Grüßen
>> ----------------------------------- Aufwind durch Wissen!
>> Qualifizierte OpenSource-Schulungen bei der www.foss-academy.eu
>> <http://www.foss-academy.eu> [5]
>> Astrid Emde WhereGroup GmbH & Co.KG Eifelstraße 7 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 19 Fax: +49(0)228 90 90 38 - 11
>> astrid.emde at wheregroup.com www.wheregroup.com
>> <http://www.wheregroup.com> [6]
>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com [7]
>> Amtsgericht Bonn, HRA 6788 -------------------------------
>> Komplementärin: WhereGroup Verwaltungs GmbH vertreten durch: Olaf
>> Knopp, Peter Stamm ------------------------------- pgp-public
>> key:
>> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>> [8] Signierte und/oder verschlüsselte Nachrichten sind sehr
>> willkommen Signed and/or encrypted mail is highly appreciated
>> _______________________________________________ Mapbender_users
>> Links: ------ [1]
> [2]
> [3]
> [4] http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> [5] http://www.foss-academy.eu [6] http://www.wheregroup.com [7]
>> http://twitter.com/WhereGroup_com [8]
> <http://www.foss-academy.eu> -----------------------------------
> Germany
> Knopp, Peter Stamm ------------------------------- pgp-public key:
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Komplementärin:
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
