[Mapbender-users] RES: Re: Help with Apache configuration (Astrid Emde)
Franklin Januario da Silva
Franklin.Silva at cerradinho.com.br
Mon Aug 17 13:05:48 PDT 2015
Thanks Astrid,
Finally got through to work after installing version 2.4 of the Apache and use the tutorial setting you indicated .
-----Mensagem original-----
De: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Em nome de mapbender_users-request at lists.osgeo.org
Enviada em: quarta-feira, 12 de agosto de 2015 16:01
Para: mapbender_users at lists.osgeo.org
Assunto: Mapbender_users Digest, Vol 105, Issue 4
Send Mapbender_users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/mapbender_users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
mapbender_users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Mapbender_users digest..."
Today's Topics:
1. Re: Help with Apache configuration (Astrid Emde)
Message: 1
Date: Wed, 12 Aug 2015 23:50:46 +0200
To: Mapbender User List <mapbender_users at lists.osgeo.org>
Cc: Franklin Januario da Silva <Franklin.Silva at cerradinho.com.br>
Subject: Re: [Mapbender-users] Help with Apache configuration
Message-ID: <7e4700722b1800e71ec94d2c8bfc2028 at wheregroup.com>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hello Franklin,
try the ALIAS like this with a / behind /mapbender3/
ALIAS /mapbender3/ c:/OSGeo4W/var/www/mapbender3/web/
<Directory c:/OSGeo4W/var/www/mapbender3/web/>
Options MultiViews
DirectoryIndex app.php
Order allow, deny
Allow from all
</ Directory>
You also may add the rewrite condition to the ALIAS.
Have a look at:
http://doc.mapbender3.org/de/book/installation/installation_windows.html
Best regards
Astrid Emde
Am 2015-08-10 18:28, schrieb Franklin Januario da Silva:
> Hello,
> I do not have much experience with server configuration, I am testing
> the application locally. Mapbender3 unzipped the files in the
> following directory:
> C: \ OSGeo4W \ var \ www \ mapbender3
> And I set up Apache as follows:
> ALIAS / mapbender3 / OSGeo4W / var / www / mapbender3 / web /
> <Directory / OSGeo4W / var / www / mapbender3 / web />
> Options MultiViews
> Order allow, deny
> Allow from all
> </ Directory>
> I ran all the commands listed in the installation tutorial as follows:
> cd \
> cd C: \ OSGeo4W \ var \ www \ mapbender3 php.exe app / console
> doctrine: database: create php.exe app / console doctrine: schema:
> create php.exe app / console init: acl php.exe app / console assets:
> install web php.exe app / console fom: user: resetroot php.exe app /
> console doctrine: fixtures:. --fixtures load = / Mapbender / src /
> Mapbender / CoreBundle / DataFixtures / ORM / EPSG / --append php.exe
> app / console doctrine: fixtures:. --fixtures load = / Mapbender / src
> / Mapbender / CoreBundle / DataFixtures / ORM / Application / --append
> The page loads incompletely and apache log indicates that the files
> are not found:
> [Mon Aug 10 13:16:56 2015] [error] [client 127.0.0.1] File does not
> exist: C: / OSGeo4W / var / www / mapbender3 / web / application,
> referer: http: // localhost / mapbender3 / [Mon Aug 10 13:16:56 2015]
> exist: C: / OSGeo4W / var / www / mapbender3 / web / js, referer:
> [Mon Aug 10 13:16:57 2015] [error] [client 127.0.0.1] File does not
> exist: C:
> /OSGeo4W/var/www/mapbender3/web/uploads/mapbender_mobile_yml/mapbender
> _mobile.png,
> referer: http: // localhost / mapbender3 / [Mon Aug 10 13:16:57 2015]
> exist: C:
> /OSGeo4W/var/www/mapbender3/web/uploads/mapbender_user_basic_yml/mapbe
> nder_user_basic.png,
> exist: C:
> /OSGeo4W/var/www/mapbender3/web/uploads/mapbender_user_yml/mapbender_u
> ser.png,
> What needs to change?
> Thanks in advance.
> [http://www.cerradinho.com/CBio.png]
> Agricola
> 64 3634-2806
> 64 9979-0608
> cerradinho.com.br<http://www.cerradinho.com.br>
> Mapbender_users at lists.osgeo.org
Mit freundlichen Gr??en
Astrid Emde
GIS-Consultant
FOSS Academy Sommerschule 2015
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
http://www.foss-academy.eu/kompaktkurse_sommerschule_2015
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstra?e 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplement?rin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschl?sselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
End of Mapbender_users Digest, Vol 105, Issue 4
Agricola
64 3634-2806
64 9979-0608
More information about the Mapbender_users
