[Mapbender-users] How to enable secure WMS layer visualization through Mapbender3
naresh naresh_n at nrsc.gov.in
Mon May 11 01:29:46 PDT 2015
Dear ALL,
   I have configured Mapbender3 in windows8 machine 64 bit. Using GUI
created the new application and added the WMS layers through Layer set ,
selected the option proxy and added the  user credentials for view. When
I Opened the application with credentials layers are loading  fine and
wms requests can be seen as follows from browser
http://localhost/mapbender3/app_dev.php/owsproxy/?url=http%3A%2F%2F192.168.180.150%3A8080%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26_signature%3D41%253ANwPvRxmwjo898lUpbVq4cPChQNk&TRANSPARENT=TRUE&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&LAYERS=boundaries%3AINDIA_STATE_250K&SRS=EPSG%3A4326&BBOX=63.823233641633,-0.59814766473471,71.95067476302,7.5292934566531&WIDTH=256&HEIGHT=256
But from above request we can get to know URL of the server and layer
name,And these can be used to access the WMS layer out side the map
bender application. So wms layer is not secured ,people can access the
wms request by seeing the details from browser. How to avoid this? or is
it possible with mapbender3 client can sends wms requests which can not
be understandable by  users.
Thanks&Regards,
Naresh
On 4/25/2015 12:31 AM, mapbender_users-request at lists.osgeo.org wrote:
> Send Mapbender_users mailing list submissions to
> 	mapbender_users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/mapbender_users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	mapbender_users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Mapbender_users digest..."
> Today's Topics:
>     1. Fwd: Mapbender_users Digest, Vol 101, Issue 5 (naresh)
> Message: 1
> Date: Fri, 24 Apr 2015 13:56:04 +0530
> From: naresh <naresh_n at nrsc.gov.in>
> To: mapbender_users at lists.osgeo.org
> Subject: [Mapbender-users] Fwd: Mapbender_users Digest, Vol 101, Issue
> 	5
> Message-ID: <5539FE1C.2070104 at nrsc.gov.in>
> Content-Type: text/plain; charset="windows-1252"; Format="flowed"
> Dear Sir,
> Please add my mail id .
> Thanks&Regards,
> Naresh
> -------- Forwarded Message --------
> Subject: 	Mapbender_users Digest, Vol 101, Issue 5
> Date: 	Thu, 23 Apr 2015 12:02:01 -0700
> From: 	mapbender_users-request at lists.osgeo.org
> Reply-To: 	mapbender_users at lists.osgeo.org
> Today's Topics:
>      1. app_dev.php  is not opening (naresh)
>      2. Re: app_dev.php  is not opening (Astrid Emde)
> Message: 1
> Date: Thu, 23 Apr 2015 14:48:57 +0530
> Subject: [Mapbender-users] app_dev.php  is not opening
> Message-ID: <5538B901.3090204 at nrsc.gov.in>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Dear ALL,
>       I have installed Mapbender3.0.4.1 on windows xp machine. I have
> followed the steps given in
> http://doc.mapbender3.org/en/book/installation.html#installation-example-for-windows.
> When i am visiting the link http://localhost/mapbender/app_dev.php ->
> the page is not showing it is  keep on loading. How to run/open the
> application.
> The following info may be helpful to understand the issue
>     1. http://localhost/mapbender3/config.php showing the following message.
>     Your configuration looks good to run Symfony.
>     * Configure your Symfony Application online
>       <http://localhost/mapbender3/app_dev.php/_configurator/>
>     * Bypass configuration and go to the Welcome page
>       <http://localhost/mapbender3/app_dev.php/>
> Even if we click on above hyper links the page was not loading.
> 2. while executing the command php.exe app/console init:acl it is shown
> the message Aborting: The table with name 'postgres:acl_classes' already
> exists
> 3. Attached  parameter.yml and config.yml file. ( where i have changed
> the paramers).
> Please give suggestion/advise how to fix the issue and explore further
> map bender option
> Thanks&Regards,
> Naresh
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20150423/70074188/attachment-0001.html>
> imports:
>       - { resource: parameters.yml }
>       - { resource: security.yml }
> framework:
>       #esi:             ~
>       translator:      { fallback: %fallback_locale% }
>       secret:          %secret%
>       router:
>           resource: "%kernel.root_dir%/config/routing.yml"
>           strict_requirements: %kernel.debug%
>       form:            true
>       csrf_protection: true
>       validation:      { enable_annotations: true }
>       templating:      { engines: ['twig'] } #assets_version: SomeVersionScheme
>       default_locale:  %locale%
>       session:
>           cookie_httponly: true
>           cookie_secure: %cookie_secure%
>           cookie_lifetime: %cookie_lifetime%
> # Twig Configuration
> twig:
>       debug:            %kernel.debug%
>       strict_variables: %kernel.debug%
>       globals:
>           fom:    %fom%
>       form:
>           resources:
>               - 'FOMCoreBundle:Form:fields.html.twig'
> # Assetic Configuration
> assetic:
>       use_controller: true
>       ruby: %ruby_path%
>       filters:
>           cssrewrite: ~
>           sass: ~
>           compass:
>               bin: %compass_path%
>               no_line_comments: true
>               style: compressed
>               load_paths:
>                    - "%kernel.root_dir%/../mapbender/src/Mapbender/CoreBundle/Resources/public/sass"
> # Doctrine Configuration
> doctrine:
>       dbal:
>           driver:   %database_driver%
>           host:     %database_host%
>           port:     %database_port%
>           dbname:   %database_name%
>           path:     %database_path%
>           user:     %database_user%
>           password: %database_password%
>           charset:  UTF8
>       orm:
>           auto_generate_proxy_classes: %kernel.debug%
>           auto_mapping: true
> # Swiftmailer Configuration
> swiftmailer:
>       transport: %mailer_transport%
>       host:      %mailer_host%
>       username:  %mailer_user%
>       password:  %mailer_password%
>       spool:     { type: memory }
> # FOM Manager Configuration
> fom_manager:
>       route_prefix: /manager
> # FOM User Configuration
> fom_user:
>       selfregister: false
>       reset_password: true
>       max_registration_time: 1
>       max_reset_time: 1
>       mail_from_address: wizard at oz.net
>       mail_from_name: Wizard of Oz
>       profile_entity: FOM\UserBundle\Entity\BasicProfile
>       profile_formtype: FOM\UserBundle\Form\Type\BasicProfileType
>       profile_template: FOMUserBundle:User:basic_profile.html.twig
>       self_registration_groups:
>           - Self Registered
>           - Demo Group
> # OWSProxy Configuration
> ows_proxy3_core:
>       logging: true
>       obfuscate_client_ip: true
>       proxy:
>           host: 172.16.0.11
>           port: 8080
>           connecttimeout: 60
>           timeout: 90
>           user:naresh
>           password:bhuvan
> #        noproxy:
> #            - host_a
> #            - host_b
> # Mapbender Configuration
> mapbender_core:
>       sass_assets: false
> parameters:
>       database_driver:   pdo_pgsql
>       database_host:     localhost
>       database_port:     5432
>       database_name:     mapbender
>       database_path:
>       database_user:     postgres
>       database_password: bhuvan
>       mailer_transport:  smtp
>       mailer_host:       localhost
>       mailer_user:
>       mailer_password:   ~
>       # locale en, de, it, es are available
>       fallback_locale:   en
>       locale:            en
>       secret:            ThisTokenIsNotSoSecretChangeIt
>       fom:
>           server_name:   Mapbender3
>           server_version: 3.0.4.1
>           server_logo:   bundles/mapbendercore/image/logo_mb3.png
>       # framework : http://symfony.com/doc/2.1/reference/configuration/framework.html#cookie-lifetime
>       cookie_secure: false
>       cookie_lifetime: 3600
>       # activate sass_assets and define the compass_path, ruby_path, if you want to work with compass and edit sass files
>       # if not leave sass_assets: false
>       sass_assets: false
>       compass_path: ~
>       ruby_path: ~
> Message: 2
> Date: Thu, 23 Apr 2015 13:41:12 +0200
> From: Astrid Emde <astrid.emde at wheregroup.com>
> Subject: Re: [Mapbender-users] app_dev.php  is not opening
> Message-ID: <5538DA58.9070501 at wheregroup.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hello Naresh,
> I think you tried to open the following link with mapbender3. You have
> firebug for your browser? You could check whether you get an error
> message there.
> Please have a look in you apache log-file too.
> These are the first advises I can give.
> Best regards Astrid
> Am 23.04.2015 11:18, schrieb naresh:
>> Dear ALL,
>> application.
>> shown the message Aborting: The table with name 'postgres:acl_classes'
>> already exists
>> the paramers).
>> map bender option
>> Thanks&Regards,
>> Naresh
>> Mapbender_users at lists.osgeo.org
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
More information about the Mapbender_users mailing list
