[Mapbender-users] tiled does not work for wms source
    Astrid Emde
    astrid.emde at wheregroup.com
    Tue Nov 10 06:37:24 PST 2015
Hi Jasper,
Am 2015-11-10 15:17, schrieb jasper oaks:
> Hi list
> I am using mapbender 3.0.5.1 and connecting to a geoserver WMS which
> has geowebcache integrated.
> When I use this wms as a layerset it works perfectly, but selecting
> the 'tiled' tick box in the layerset config page does not add
> tiled=true to the wms url request. I have checked the geoserver logs
> and turning on and off tiled does not change the url parameter to true
> or false, tiled is always false.
It is a misunderstanding. Tiled as Mapbender3 setting only means that
the service is requested with many GetMap-Requests instead of one.
> I have tested turning transparency on and off in layerset settings and
> this does change the transparency url parameter, so it seems it is
> just the tiled functionality that does not work.
Transparency setting in Mapbender on/off checkbox does not change
transparency in MapRequest
&TRANSPARENT=TRUE&
If you set opacity = 80 f.e the Maprequest is not effected but the image
gets a opacity in the client afterwards.
Astrid
> Anyone else encounter this issue?
> Jasper
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B Konferenz 2015
10. Dezember 2015 in Bonn
www.where2b-conference.com
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
  pgp-public key:
  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
