[Mapbender-users] Connection error with geometry server, internal error 500
zh.kerimkulov at gharysh.kz
Sat Apr 30 00:09:15 PDT 2016
Hello Mapbender Users!!!
I tried to use Digitizer element, but faced connection error with geometry server.
Step by step:
1/ I changed config.yml file:
doctrine:
dbal:
default_connection: default
connections:
default:
driver: %database_driver%
host: %database_host%
port: %database_port%
dbname: %database_name%
path: %database_path%
user: %database_user%
password: %database_password%
charset: UTF8
logging: %kernel.debug%
profiling: %kernel.debug%
search_db:
driver: %database2_driver%
host: %database2_host%
port: %database2_port%
dbname: %database2_name%
path: %database2_path%
user: %database2_user%
password: %database2_password%
charset: UTF8
2/ and parameters.yml file.
parameters:
# database-connection "default"
database_driver: pdo_pgsql
database_host: localhost
database_port: 5432
database_name: mapbender3
database_path: ~
database_user: postgres
database_password: postgres
# database-connection "search_db"
database2_driver: pdo_pgsql
database2_host: localhost
database2_port: 5432
database2_name: search_db
database2_path: ~
database2_user: postgres
database2_password: postgres
3/ then I tried to create DB by console utility like this: app/console doctrine:database:create
But this utility create only default DB, search_db did not created by script. I create it manually and added extension Postgis. After that I added tables with SQL query for tables table public.poi, public.polygons, public.lines, then I added Digitizer element to the side panel of application and put YAML-Definition to the textarea schemes but it did not solve the problem, I still have "Connection error with geometry server, internal error 500".
Thank you,
Zhandos
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160430/f3dd222e/attachment.html>
More information about the Mapbender_users
