[Mapbender-users] Mapbender 2.7.4: Customizing the display of WFS layers
Jäger, Frank (KRZ)
F.Jaeger at KRZ.DE
Tue Feb 9 02:30:29 PST 2016
Hi Lucas,
to see the WFS-Conf it isn't necessary to assign it to "myGUI" but to any gui.
Create a new (empty) gui to assign it to.
* To use a WFS(-T)-Conf for digitize:
- Assign the WFS-Conf to the GUI.
- Assign the WFS-Conf-ID to the corresponding WMS-Layer:
"WMS Anwendungseinstellungen" / "setWFS"
* To use a WFS-Conf for Search:
Add the WFS-Conf-ID to the "comma seperated list of WFS conf ids":
"Edit Element Vars" of GUI / "gazetteerWFS"
Element: "wfsConfIdString"
You must not assign it to the GUI.
Frank
> -----Ursprüngliche Nachricht-----
> Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im
> Auftrag von lukas.bollack
> Gesendet: Dienstag, 9. Februar 2016 11:02
> An: Mapbender_users at lists.osgeo.org
> Betreff: Re: [Mapbender-users] Mapbender 2.7.4: Customizing the display of
> WFS layers
> Hi Frank
> Thanks for the explanation! So it should be ok if I just keep using the same
> values as in the pre-configured wfs-services (myPoints etc).
> What seems weird to me is that I removed the wfs-configurations of myPoints
> and the other pre-configured wfs-services from my gui (under "WFS-
> Konfiguration GUI zuweisen") and also the associated wms ("My Edit
> Elements") is not associated with my GUI (under "WMS-
> Anwendungseinstellungen"). When I use the digitize module, the preconfigured
> wfs-services don't show up anymore, but in the search module, they are still
> there! Also, my own wfs-services show up in the digitzer, but not in the search
> module! (even though I checked "search" for some of their attributes in the
> wfs-configuration).
> Is there another menu I don't know of where you define which layers are
> searchable via the search module?
> Regards
> Lukas
> View this message in context: http://osgeo-
> org.1560.x6.nabble.com/Mapbender-2-7-4-Customizing-the-display-of-WFS-
> layers-tp5249094p5249657.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160209/2d29e6b5/attachment.bin>
More information about the Mapbender_users
