[Mapbender-users] Mapbender 2.7.4: A couple of questions
Jäger, Frank (KRZ) F.Jaeger at KRZ.DE
Mon Feb 15 10:03:20 PST 2016
Hi Lukas,
the first WMS is by default the wms for the overview. A Mapbender-GUI starts by default in the max. extent of the Overview when startet from the GUI-List.
You can limit the max. scale of the gui with element "setScaleHint". Then the mapframe starts in the center of the overview but you cannot extend the frame when the GUI is loaded. Its only usefull when you have no WMS - except the overview - that serves the small scale on max. extent.
See:  http://mapbender2.org/SetScaleHint
You can start the GUI from an generated URL with a Position and Scale. But you have to serve GUI, User, Passwort(!) and "mb_myPOI2SCALE" in the URL. Don't use your administrative User-ID. I use a little script to set and hide the parameters: http://map.krz.de/cms/cms2mapu.php?id=466
See  http://mapbender2.org/Mod_setPoi2Scale
You can also set a label like in http://map.krz.de/cms/cms2mapu.php?id=90
See http://mapbender2.org/HighlightPOI
URL like ...
...login.php?name=
&password=
&mb_user_myGui=
&mb_myPOI2SCALE=
&mb_myPOI=
Frank
> -----Ursprüngliche Nachricht-----
> Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im
> Auftrag von lukas.bollack
> Gesendet: Montag, 15. Februar 2016 18:07
> An: Mapbender_users at lists.osgeo.org
> Betreff: Re: [Mapbender-users] Mapbender 2.7.4: A couple of questions
> How do I set the bounding box for my map window (mapframe1) as well as the
> overview window (overview)? Does the module take this directly from the
> bounding box of the background wms?
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160215/e714bd9f/attachment.bin>
More information about the Mapbender_users mailing list
