[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath armin.retterath at gmail.com
Fri Feb 26 13:25:21 PST 2016
The editor is vi - or install nano first - it is easier to use. apt-get
install nano - in root shell or do it with sudo
Am 26.02.2016 22:23 schrieb "Armin Retterath" <armin.retterath at gmail.com>:
> Yes - you need a editor - but you may edit proxy.conf in mods.available
> and before this disable mod proxy like a2dismod proxy - this may delete
> mods-enabled/proxy.conf first. After editing mods-available/proxy.conf
> enable it again with a2enmod proxy. Maybe in your environment the files in
> the enabled folder just link to those in the available folder ;-)
> Am 26.02.2016 21:09 schrieb "lukas.bollack" <lukas.bollack at naturnetz.ch>:
>> I can edit all the conf files just fine, only the files in mod-enabled
>> can't
>> be opened. Webmin says: "only normal files can be edited". I edited
>> proxy.conf via webmins file manager in mods-available but this seems to be
>> the wrong one. My server runs Ubuntu Linux 12.04.5. Is there a way to open
>> proxy.conf in the shell?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5253094.html
>> Sent from the mapbender-users mailing list archive at Nabble.com.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160226/b7667375/attachment.html>
More information about the Mapbender_users mailing list
