[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Mon Feb 29 06:27:20 PST 2016
hi lukas,
here is my devel apache2 conf part in
/etc/apache2/sites_available/default (ubuntu 12.04 lts - desktop)
this should be easily adopted to your path ;-) :
Alias /owsproxy
/home/armin/GDI-RP/Geoportal/devel/mb_trunk/owsproxy
<Directory /home/armin/GDI-RP/Geoportal/devel/mb_trunk/owsproxy/>
Options +FollowSymLinks
ReWriteEngine On
RewriteBase /owsproxy
RewriteRule ^([\w\d]+)\/([\w\d]+)\/?$
http://127.0.0.1/owsproxy/http/index.php?sid=$1\&wms=$2\& [P,L,QSA,NE]
Options +Indexes
Allow from all
</Directory>
Alias /cors_proxy
/home/armin/GDI-RP/Geoportal/devel/mb_trunk/cors_proxy
<Directory
/home/armin/GDI-RP/Geoportal/devel/mapbender_trunk/cors_proxy/>
ReWriteEngine On
RewriteBase /cors_proxy
RewriteRule ^([\d]+)?$
http://127.0.0.1/cors_proxy/http/index.php?wmsid=$1\& [P,L,QSA,NE]
Options +Indexes
Allow from all
</Directory>
Alias /http_auth
/home/armin/GDI-RP/Geoportal/devel/mb_trunk/http_auth
<Directory /home/armin/GDI-RP/Geoportal/devel/mb_trunk/http_auth/>
Options +FollowSymLinks +Indexes
ReWriteEngine On
RewriteBase /http_auth
RewriteRule ^([\d]+)\/?$
http://127.0.0.1/http_auth/http/index.php?layer_id=$1 [P,L,QSA,NE]
Order allow,deny
Allow from all
</Directory>
hope this help
armin
On 29.02.2016 14:50, lukas.bollack wrote:
> Two things that I have found while searching the mailing list:
> One time you refer to making an entry in
> /etc/apache2/sites-available/default (found here:
> https://lists.osgeo.org/pipermail/mapbender_users/2012-September/004236.html).
> Is this a necessary step and if yes, what do I need to do there?
> Another time you refer to defining an Alias for http_auth (found here:
> https://lists.osgeo.org/pipermail/mapbender_users/2013-May/004392.html). Is
> this a necessary step if I want to use a password protected wms service in
> my application?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5253385.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users
