[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath armin.retterath at gmail.com
Mon Feb 29 10:01:13 PST 2016
if you use the normal apache2 php5 module, the $_SERVER['HTTP_HOST']
 variable will give the server name like it is invoked to the php script.
therefor it will work for named server as it work for invocation via ip ;-)
2016-02-29 15:57 GMT+01:00 lukas.bollack <lukas.bollack at naturnetz.ch>:
> ok thanks!
> Do I make the exact same entry, or do I need to customize this part?
> ".$_SERVER['HTTP_HOST']
> My server has IP "http://188.226.178.194" and domain "naturnetz.com"
> http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5253404.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160229/0528ef70/attachment.html>
More information about the Mapbender_users mailing list
