[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath armin.retterath at lvermgeo.rlp.de
Mon Jan 11 05:54:46 PST 2016
hi lukas,
i forgot something:
if you use authenticated services in mapbender, the client also use this
services via the mapbender internal owsproxy. you have to configure this
proxy to see the services in the client ;-) :
http://www.mapbender2.org/Owsproxy
for debian 6/7/8 use the usage of mod_rewrite is preferred:
http://www.mapbender2.org/Owsproxy#2._rewrite_.28bevorzugte_Methode.2C_vor_allem_f.C3.BCr_Mapbender-Versionen_.3E.3D_2.7.x.29
regards
armin
On 11.01.2016 13:42, lukas.bollack wrote:
> Hi Armin
> Ok so I installed the curl library using the command line ("sudo apt-get
> install php5-curl", then restart the server with "sudo service apache2
> restart"). I'm using Ubuntu Linux 12.04.5, but didn't set it up myself, it's
> a mapserverpro.com-server.
> Am I right when I change my settings in mapbender.conf to the following:
> define("CONNECTION", "curl");
> #define("CONNECTION", "http");
> #define("CONNECTION", "socket");
> define("CONNECTION_PROXY", "");
> define("CONNECTION_PORT", "");
> define("CONNECTION_USER", "<user>");
> define("CONNECTION_PASSWORD", "<password>");
> Thanks
> Lukas
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5244539.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
